JMS583 chip
  • Max88
  • Max88's Avatar
  • Poster
  • Poster
Re: JMS583 chip
4 years 2 weeks ago
you just have to change it at the top then reflash the firmware I put the file for you
When I start the Tool it always gives me an error as before, to use it I have to modify the ini file and change the path of the bin file by inserting my
  • Max88
  • Max88's Avatar
  • Poster
  • Poster
Re: JMS583 chip
4 years 2 weeks ago - 4 years 2 weeks ago
Are the settings of the INI file you sent me correct? If I leave FAT32 later can I format to NTFS? RD version I leave it without check? S / N string, do I need to enter another value?
Also in the ini file, do I have to leave these two items as they are by default? FreeSpace and FwFileName?
Last edit: 4 years 2 weeks ago by Max88.
Re: JMS583 chip
4 years 2 weeks ago
I leave it by default
  • Max88
  • Max88's Avatar
  • Poster
  • Poster
Re: JMS583 chip
Re: JMS583 chip
4 years 2 weeks ago
When you update it leave by default everything except the ID code 0683 do not touch the partition or others
