- lupusbytes
1 year 6 months ago
After the update it showeddriver: atlantic
version: 6.14.7-gentoo
firmware-version: 1.3.24
After rebooting I had no network.driver: atlantic
firmware-version: 1.3.33
- The lights are on in the network interface
- The operating system recognizes the NIC and thinks it's active; enp13s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
- The switch recognizes a link
- No packets can be sent or received. tcpdump only shows "unanswered" ARP traffic from the interface
- lupusbytes
1 year 6 months ago
I fixed my issue.
It was as simple as pulling the power cable after updating. See also www.station-drivers.com/index.php/en/for...r-edit?start=80#4865
- jumpy76
1 year 4 months ago
I'm trying to update the AQC113CS on my MSI Z790 Godlike Max, I get this error:
A driver can't load on this device
Do you have a suggestion? Disable Windows drivers signature perhaps?
Thank you very much!
- jumpy76
Can someone help, please? I disabled secure boot and core isolation (it's 0 in regedit), but I still get the message "impossible to load atlAccess.sys driver".
