2 years 1 month ago
Ok so when you launch the firmware update it no longer detects the AQC113?
Same in the device manager it no longer appears?
- Kr1s
2 years 1 month ago
Yep,i can't find it,and nomore device without driver,even in the bios, mac shows N/A
- hade
2 years 1 week ago
Hello
I have two Marvell® AQtion AQC113C in my system.
The first one comes with the Z790 AORUS MASTER motherboard and the second one comes with the VISION 10G LAN Card.
First I want to know the firmware version of both, then I can start the update.
Who can help me?
Thanks
Who can help me?
Thanks
Hi be careful because some people encounter problems with updates that fail I have the Z790 Proart and the X670 Proart and no worries both
here is the procedure to know how to do it
Last edit: 2 years 1 week ago by admin.
The following user(s) said Thank You: hade
- castle76
1 year 7 months ago
Hello, I also have the Asus ProArt Z790 and I am a bit confused on how to update the marvel 10g on board nic firmware? My goal is to enable ASPM in Linux (Do I use the DirtyWake firmware and remove the other two, antigua and foxconn from the directory?). I created a bootable windows pe to use and also disabled secure boot. However I am unsure which file I should run? Any help would be greatly appreciated thank you.
