Intel Management Engine Interface (MEI/AMT) Version 2435.6.35.0
- SM-003
- Moderator Global
Re: Intel Management Engine Interface (MEI/AMT) Version 2435.6.35.0
As I am only interested in MEi driver so extracted the MEI only driver folder but noticed there's only one folder for win8, nothing for win10/11
tried installing the same over 2428.6.2.0 from device manager but not installed.
Last edit: 6 months 2 weeks ago by SM-003.
- Ataemonus
That one is for Win8 only. Try this :
www.elevenforum.com/t/drivers-intel-chip...d-6xx-7xx-8xx.11946/
Last edit: 6 months 2 weeks ago by Ataemonus.
- Fernando
6 months 2 weeks agoIf you do a look into the related heci.inf files you will realize, that the Intel HECI driver v2433.6.3.0 dated 15.08.2024As I am only interested in MEi driver so extracted the MEI only driver folder but noticed there's only one folder for win8, nothing for win10/11
a) supports all Windows Operating Systems from Win8-11, but
b) doesn't support all Intel(R) Management Engine Interface DeviceIDs, which are supported by the v2428.6.2.0 driver.
- tistou77
Et pas pour Windows 10/11 non plus il semblerait
Le driver est estampillé TEEDriverW8x64.sys et non TEEDriverW10x64.sys
- Fernando
6 months 2 weeks ago - 6 months 2 weeks agoNéanmoins, Win10 et Win11 sont également pris en charge, mais malheuresement pas pour tous les appareils disponibles.Et pas pour Windows 10/11 non plus il semblerait
Mon conceil: Prenez le driver lié: >ici< .
Last edit: 6 months 2 weeks ago by Fernando.
