cpu Intel Management Engine Interface (MEI/AMT) Version 2435.6.35.0
  • Tom's Avatar
Re: Intel Management Engine Interface (MEI/AMT) Version 2435.6.35.0
6 months 4 days ago
#3658
Sorry to bring that up again, but I just figured out when you install the Windows 8 driver, you lose the Intel(R) Dynamic Application Loader Host Interface, the Intel(R) iCLS Client and the Intel(R) Management Engine WMI Provider under Software Components in Windows 11 24H2.
I don't know whether it is the same under Windows 10 or Windows 11 23H2.
So, install the driver linked above from @Fernando, which works fine.
  • oemuser
  • oemuser's Avatar
  • Poster
  • Poster
6 months 4 days ago
#3659
Yes it looses, i also didn't noticed that on 22 Set when was published... till Fernando mentioned and shared the link for the correct version.
All normal now, cheers.
