  • cyberops
  • cyberops's Avatar
3 years 6 months ago
This Github issue is for RTL9210 revision A. Revision B is not affected by this issue.
So, which USB enclosure chipset do you use? RTL9210 or RTL9210B?
EDIT: my bad: github.com/raspberrypi/linux/issues/4130...uecomment-1272172747
I use RTL9210B
It is possible that the intensity of the port is not enough powered the disk in USB 2.0
  • Alien Invader
  • Alien Invader's Avatar
Good Evening to all! Anyone else having trouble getting the 9210B (unionsine MD202) recognizing SM2263XT nvme drives ? My intenso premium nvme 1tb cannot be detected at all, tried 3 different firmwares without any luck. The other NVME I have around with RTS5765DL works just fine and btw I'm using the latest 1.32.49 from this thread!
  • cesarjapa79
  • cesarjapa79's Avatar
Hello! I’m new in this forum. Sorry for my bad English.
I have the Orico M2R2-G2
[url] www.orico.cc/usmobile/product/detail/id/7775.html [/url]
try to upgrade for the version 1.32.49.140423 and my RGB gone, and Windows says that my
drive is write protect.
anyone can help?
Have you saved your configuration before to reconfigure it with the new firmware (activation of RGB LEDs, activity of the disk LED, ...)
