#537
Asmedia ASM-2364 NVMe/USB 3.1 Controller firmware Version 201012_91_00_00
Here is the firmware performancen If you have more recent, I'm interested
ASM-2364 NVMe/USB 3.2 Controller (station-drivers.com)
The following user(s) said Thank You: hummingbird
  • hummingbird
  • hummingbird's Avatar
Re: Asmedia ASM-2364 NVMe/USB 3.1 Controller firmware Version 201012_91_00_00
1 year 7 months ago
#1572
I've flashed successfully from the 2019 FW to this 2020 FW no problem on my Orico with 2364 chipset www.amazon.com/gp/product/B0B27CWK1V
Will update if I run into any problems but working great so far.
I then tried to flash AS_PCIE_210527_81_3A_00 but it returns Chip & FW don't match. I've tried flashing with the controller programmed ahead of time with product ID 2362 or 2364. Either way doesn't work.
I'm noticing that even though ASM-2362 and ASM-2364 are the same series, nearly all discussion regarding AS_PCIE_210527_81_3A_00 is of users with ASM-2362. Maybe there is something meaningfully different that won't allow the 2362 firmware to be flashed to my particular Orico with 2364 controller.
1 year 7 months ago
#1575
I have an Asm2364 and I also have the same problem, I think that the firmware is different ?
  • wade7575
  • wade7575's Avatar
#1618
I'm getting a Yottamaster enclosure that has a ASM2364 and I was wondering what I need to know before updating the firmware.
Is it like updating a RTL9210B controller where you need a certain configure file for your certain model of enclosure.
I'm getting the 20Gbps model in the link.
yottamaster.com/en-ca/products/yottamast...riant=40101060247670
Last edit: 1 year 6 months ago by wade7575.
  • wade7575
  • wade7575's Avatar
#1627
@Galixte I was wondering if you can provide step by step instructions on how to flash an ASM2364 chip,I have seen a video and I know it's not as straight forward as flashing a RTL9210B controller.
I watched this video and I can see the guy load in a .Bin file but I don't have a .Bin file for the Yottamaster enclosure is it possible to make your own .Bin folder by reading the enclosure somehow with the MPTool.
The other thing I don't understand is why the guy has to make a new .Bin in the video,do you have to make a new .Bin file every time you want to flash the enclosure with new firmware.
I have the Yottamaster 20Gbps(NVMe)-Grey enclosure from this link.
The following user(s) said Thank You: viktorhun
