- wade7575
1 year 6 months agoThis message contains secure information
1 year 6 months ago
I have An Integral branded Phison PU31 Pro with and ASM 2364 the firmware is as follows
asm_fw_200505_90_00_00_ASM2364
I have a dump with the nvram
does anyone know how i can update it keeping the current nvram intact
- skan
1 year 5 months ago
I've found this ASM-2364 NVME enclosure quite cheap. It doesn't have any brand.
Do you think it's a good one? Fast (20Gbps)? Reliable? Thermal problems?
www.aliexpress.com/item/1005006075349980.html
1 year 5 months agoConfiguration
- twindragon6
I bought two of them, they work great! Can't beat the price. They have legit ASM2362 IC's in them. I would recommend removing the controller from the unit and adding a thicker silicon pad, the stock one does not make good contact with the IC. I just stacked a blue one out of the kit on the existing one for the ASM2362 but its a little thick. The unit runs warmish but cool.
They have the same firmware as this:
www.silverstonetek.com/en/product/info/storage/MS12/
www.silverstonetek.com/en/ajax/download....W%20201012910000.zip
Last edit: 1 year 3 months ago by twindragon6.
