Hauppauge WinTV Update ( 43251 ) DVB-S2 Drivers ( 08.09.2025 )
  • fikotr74
  • fikotr74's Avatar Topic Author
Hauppauge WinTV Update (43251) DVB-S2 Drivers (08.09.2025)
2 years 10 months ago - 11 months 4 weeks ago
WinTV v10 Users Manual Download
Please note:
 due to changes in Microsoft's code signing policy for Windows 7 and 8, new drivers cannot be signed for the 64-bit version of Windows 7 and 8. The WinTV v10 application will work, but the drivers will not install without warning messages. Windows 10 and 11 will install normally.Windows 10 and 11 DriversWindows 10 requires special drivers to avoid errors during the Hauppauge product installation. The latest versions of WinTV v10, WinTV 8.5, WinTV v8 and Hauppauge Capture include these drivers. But if you are looking just for the Windows 10 driver, these are updated drivers which can be used with Windows 10.WinTV and HD PVR DriversEuropean products.
  • WinTV-dualHD, WinTV-soloHD
    Note: Combo driver for Win10/11 and Win7/8
  • WinTV-HVR-935 (Europe DVB, all models)
  • WinTV-NOVA-S2, 461e
  • WinTV-quadHD PCIe model 17xx (new model, after August 2022)
  • WinTV-quadHD PCIe model 16xxxx (old model), WinTV-HVR-1265, WinTV-HVR-1250, WinTV-HVR-1260, ImpactVCBe
  • ImpactVCB-e and WinTV-HVR-1265
    Note: Windows 10/11 driver for new models #180100 and 180111 plus the older ImpactVCB-e3 and WinTV-HVR-1265
  • Starburst 2, WinTV-HVR-12xx, WinTV-HVR-1700, WinTV-HVR-1500, WinTV-HVR-1400, ImpactVCBe (old model)
    WinTV-HVR-55xx, WinTV-HVR-44xx, WinTV-HVR-33xx (150xxx, 121xxx, 53xxx, 69xxx)
  • USB-Live2 (new model 122020)
  • USB-Live2 (old model 122000)
  • WinTV-NOVA-S-USB2, WinTV-NOVA-HD-USB2
  • WinTV-Nova-T stick, WinTV-Duet, WinTV-Nova-TD
  • WinTV-HVR-900 (65xxx), WinTV-HVR-930 (16xxx)
  • WinTV-Ministick, WinTV-Ministick2
  • WinTV-HVR-1110
  • HD PVR 2 (all models)
  • Colossus2
North America products
  • WinTV-HVR-955Q, WinTV-HVR-950Q, WinTV-HVR-950 and Xbox One TV tuner (ATSC)
  • WinTV-dualHD
  • WinTV-quadHD PCIe model 16xxxx (old model, before August 2022), WinTV-HVR-1265, WinTV-HVR-1250, WinTV-HVR-1260, ImpactVCBe
  • WinTV-HVR-2255, WinTV-HVR-2250, WinTV-HVR-2200
  • WinTV-HVR-1975, WinTV-HVR-1955, WinTV-HVR-1950
  • WinTV-quadHD USB
  • Colossus2
  • HD PVR 60
  • WinTV-HVR-950 (65xxx), WinTV-HVR-850 (65xxx), WinTV-HVR-850 (111xxx)
  • HP Model 133xxx
Hauppauge WinTV TV CARD OLD DRiVERS  Version: 41277   ( 04.10.2023 )    Note: Updated driver is in the latest messages.
WinTV v10 & DRiVERS DOWNLOAD      Release notes WinTV v10.0.41277
  • Matches New WinTVSDK release
  • Fixes an issue with blocky TV image on certain satellite DVB-S2 channels.
  • Updated hcw85bda driver 1.60.41271 for WinTV-HVR-5525/WinTV-Starburst2 latest revision
New features:New satellite channel table for Astra 19.2E and new satellite FM radio stations
Record to network drive (NAS drive). The latest version of WinTV v10 will automatically move your recordings to a network drive after the recordings are complete, freeing up space on your local disk
XMLTV guide data now supported*Please note: due to changes in Microsoft's code signing policy for Windows 7, new drivers cannot be signed for the 64-bit version of Windows 7. The WinTV v10 application will work, but the drivers will not install without warning messages on Windows 7.
Last edit: 11 months 4 weeks ago by fikotr74.
  • fikotr74
Re: Hauppauge WinTV TV DVB-S2 Card Drivers 43217 ( 05.08.2025 )
  • updated WinTV Recorder, to fix issues starting multiple recordings at the same time which could cause recording failures
  • optimised WinTV Recorder mutex changes, to avoid waiting a further 2 seconds to release the mutex compared with 43216
Note: On some computers, if you encounter errors such as sound playing but no image in H 264 & H265 broadcasts, you may need to enable Hardware Acceleration.
WinTV v10.0.43217    >>>>>>>>>>
  DOWNLOAD <<<<<<<<<<  ( 05.08.2025 )  ===> ALTERNATiVE DOWNLOAD
Last edit: 1 year 1 month ago by fikotr74.
  • fikotr74
Re: Hauppauge WinTV Update ( 43251 ) DVB-S2 Drivers ( 08.09.2025 )
11 months 4 weeks ago - 11 months 4 weeks ago
WinTV v10.0.43251 (BETA)    DOWNLOAD   (08.09.2025)
  • Bug fix for video format setting (NTSC,PAL) when using the ImpactVCB-e and USB-Live2. The video format was not correctly set, causing video format issues
  • Updated Satellites.xml frequency list for 160.0E and renamed from OPTUS D1 to MEASAT 3A / KOREASAT 6. Also updated satellite channel list for New Zealand.
  • Fixed an issue where the padding time could be set to a negative value, causing a recording to fail.
  • Added more logging to WinTV Recorder around padding conflicts.
Beta version :  Includes improvements to the WinTV Scheduler to fix reported missed recordings plus a bug fix for the ImpactVCB-e and USB-Live2
