  • Silverian
  • Portrait de Silverian
il y a 2 mois 4 semaines - il y a 2 mois 4 semaines
  • I am not not sure why, but even if hardware ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0295&SUBSYS_103C8615 is present inside every HDXHAPHPNB.inf driver I have tested (supposed to be compatible), I am still getting the BSOD.
Hi Silverian,
Hello josefrancklin, thank you for your response!
Very good catch mentioning the AMD driver "amdacpksl.sys", a.k.a. as the AMD Audio CoProcessor, let me start by clarifying there is a known issue with this driver affecting HDAUDIO\FUNC_01&VEN_10EC&DEV_0295&SUBSYS_103C8615 that causes loud static / crackling noise, for that reason I am permanently avoiding the 6.x.x.xx versions and stuck with 2.xx.x.xx versions, right now I am using v2.89.0.86 in case you want to know.
On the other hand, I didn't know you could filter drivers in the Microsoft Update Catalog using the SUBSUYS, very interesting. I tested a couple but got the same BSOD result unfortunately.
[color=#1e1e1e]******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: 0000000000000b50, memory referenced Arg2: 0000000000000002, IRQL Arg3: 0000000000000001, bitfield : bit 0 : value 0 = read operation, 1 = write operation bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: fffff804dc8b3a47, address which referenced memory Debugging Details: ------------------ *** WARNING: Unable to verify timestamp for RTKVHD64.sys KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 2500 Key : Analysis.Elapsed.mSec Value: 3609 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 1046 Key : Analysis.Init.Elapsed.mSec Value: 11416 Key : Analysis.Memory.CommitPeak.Mb Value: 85 Key : Analysis.Version.DbgEng Value: 10.0.29617.1000 Key : Analysis.Version.Description Value: 10.2604.29.1 amd64fre Key : Analysis.Version.Ext Value: 1.2604.29.1 Key : Bugcheck.Code.LegacyAPI Value: 0xa Key : Bugcheck.Code.TargetModel Value: 0xa Key : Dump.Attributes.AsUlong Value: 0x21808 Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0x0 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: AV_RTKVHD64!unknown_function Key : Failure.Exception.IP.Address Value: 0xfffff804dc8b3a47 Key : Failure.Exception.IP.Module Value: nt Key : Failure.Exception.IP.Offset Value: 0x2b3a47 Key : Failure.Hash Value: {8427c922-ba45-a12b-e45a-4e0138637121} Key : Faulting.IP.Type Value: Paged Key : Hypervisor.Enlightenments.ValueHex Value: 0x749fcf96 Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 1 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 0 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 0 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 0 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 0 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 38277359 Key : Hypervisor.Flags.ValueHex Value: 0x24810ef Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015 Key : Hypervisor.RootFlags.ValueHex Value: 0x3f7 BUGCHECK_CODE: a BUGCHECK_P1: b50 BUGCHECK_P2: 2 BUGCHECK_P3: 1 BUGCHECK_P4: fffff804dc8b3a47 FILE_IN_CAB: 083026-15296-01.dmp TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b DUMP_FILE_ATTRIBUTES: 0x21808 Kernel Generated Triage Dump FAULTING_THREAD: [/color][color=#0000ff]ffff988566137080 [/color][color=#1e1e1e]WRITE_ADDRESS: fffff804dd5c54d8: Unable to get MiVisibleState 0000000000000b50 BLACKBOXBSD: 1 ([/color][color=#0000ff]!blackboxbsd[/color][color=#1e1e1e]) BLACKBOXNTFS: 1 ([/color][color=#0000ff]!blackboxntfs[/color][color=#1e1e1e]) BLACKBOXPNP: 1 ([/color][color=#0000ff]!blackboxpnp[/color][color=#1e1e1e]) BLACKBOXWINLOGON: 1 ([/color][color=#0000ff]!blackboxwinlogon[/color][color=#1e1e1e]) ([/color][color=#0000ff]!blackboxwinlogonnotify[/color][color=#1e1e1e]) CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System IP_IN_PAGED_CODE: nt!KeCancelTimer+67 fffff804`dc8b3a47 f00fba2f07 lock bts dword ptr [rdi],7 STACK_TEXT: ffff948c`32bb8128 fffff804`dccc04e9 : 00000000`0000000a 00000000`00000b50 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx ffff948c`32bb8130 fffff804`dccbb7a8 : 00000000`00000000 00000000`00000000 00000000`00000b50 00000000`00000000 : nt!KiBugCheckDispatch+0x69 ffff948c`32bb8270 fffff804`dc8b3a47 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff804`dc8d447b : nt!KiPageFault+0x468 ffff948c`32bb8400 fffff804`7dd10062 : 00000000`00000000 fffff804`7dece0d0 00000000`00000000 ffff9885`73ea9460 : nt!KeCancelTimer+0x67 ffff948c`32bb84a0 00000000`00000000 : fffff804`7dece0d0 00000000`00000000 ffff9885`73ea9460 ffff9885`74b06d00 : RTKVHD64+0x40062 SYMBOL_NAME: RTKVHD64+40062 MODULE_NAME: [/color][color=#0000ff]RTKVHD64 [/color][color=#1e1e1e]IMAGE_NAME: RTKVHD64.sys STACK_COMMAND: [/color][color=#0000ff].process /r /p 0xffff9885604b1040; .thread /r /p 0xffff988566137080 ; kb [/color][color=#1e1e1e]BUCKET_ID_FUNC_OFFSET: 40062 FAILURE_BUCKET_ID: AV_RTKVHD64!unknown_function OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {8427c922-ba45-a12b-e45a-4e0138637121} Followup: MachineOwner --------- [/color]
This is the .dmp WinDbg log in case anyone else is curious to assist.
  • josefrancklin
  • Portrait de josefrancklin
Value: 1
Check Windows Security Center app, go to "Device Security" > "Core isolation" details > disable "Memory Integrity" (and if appears, also disable "Local Security Authority Protection").
Reboot and try updating driver again.
If BSOD still persists and you are able to downgrade Realtek driver first, try to update from older than 6.0.9850.1 directly to newest without passing the 6.0.9850.1. Or try to install the default "High definition audio device" first and then directly update to newest Realtek.
  • oemuser
  • Portrait de oemuser
Realtek ALC265 is OLD. (Correction, seems to be ALC295...)
Core isolation doesn't impact here, the BOSD is caused by loaded attempted driver.
  • Silverian
Oemuser,
You are absolutely right, I have tested with and without Core isolation and it makes no difference.
By any chance, do you have any other suggestions?
Les utilisateur(s) suivant ont remercié: THEBOSS619, fikotr74
  • rvail
  • Portrait de rvail
@ Silverian : try using "Display Driver Uninstaller" (free) which includes the ability to completely uninstall all remnants of Realtek, NVidia & AMD audio drivers.
Note: should be run while booted into Windows Safe Mode for best results.
