Mainpage -> Drives -> Management Engine Firmware Link broken
- Absent
il y a 11 mois 1 semaine - il y a 11 mois 1 semaine
Tried to access the ME Firmware Page for v16.x, every time I click on it, I am redirected to Divers / Utilities.
A direct link shows only the firmwares from v6-11.
And is it only me, but today SD is very slow to open links from the mainpage.
Re: Mainpage -> Drives -> Management Engine Firmware Link broken
Hi yes I think there are people that will explain the problem, I will keep an eye on it
Les utilisateur(s) suivant ont remercié: duttyend, fikotr74
- Absent
Thanks, but how about the missing firmware for MEI?
If there are too many downloads on ME firmwares, the option temporarily disappears until the server is no longer overloaded sd11
the ME firmwares are back including 16.x but I continue to look for the reason for the errors sd26
Les utilisateur(s) suivant ont remercié: Tom, duttyend, fikotr74
