Hi, did you install the latest drivers (3.1.11.0)? If not, try older firmware versions.
Try restoring the latest BIOS just in case, and do a CMOS clear even though I don't think it will help.
- Milan
I have tried probably every driver, cleared cmos its been like this for about 2 months and I decided to give up, since I couldnt get on here.
I read that some people have flashed there with the ch341a?
Do you perhaps know how?
Every cfx I download is 1-5KB to big and I cant really find if the bootloader is included in the cfx files.
you can unbrick it without a ch341 i posted about how to about 2 years ago here
- giaanc
I was able to flash the PS/1 card successfully without modifying the firmware using `--update`. This is on an Asus Proart x670-E motherboard. It's working correctly so far, and I'm on the latest firmware.
My only question is that I understand this adapter is PCI Gen4.
However, HWInfo64 on Gen3,I understand it should be Gen4 x1 Is anyone else experiencing this?
- giaanc
In response to my previous post: it was indeed the firmware.
I reinstalled the firmware at 1.5.39 specifically, this one with Hiren's BootCD AQC113-Asus_Bx-1.5.39_bdp_aqsign.clxand it's back to normal at Gen4 x1.
I hope this information helps someone else, because I couldn't find anything else about it.
