Intel I226–V Lan Controllers Firmware NVM Version 2.29/2.32
il y a 7 mois 2 semaines - il y a 7 mois 2 semainesMy chipset
NVMUpdate version 1.42.8.0
Copyright(C) 2013 - 2024 Intel Corporation.
nvmupdatew64e.exe -i -l inventory.txt
Config file will not be read.
Inventory
[00:133:00:00]: Intel(R) Ethernet Controller I226-V
Flash inventory started.
Shadow RAM inventory started.
Flash inventory finished.
Vendor : 8086
Device : 125C
Subvendor : 1043
Subdevice : 8867
Revision : 6
LAN MAC : xxxxxxxxxxx
Alt MAC : 000000000000
SAN MAC : 000000000000
ETrackId : 8000039D
SerialNumber : A0AD9FFFFFA10858
NVM Version : 2.35(2.23)
PBA : G23456-000
VPD status : Not set
VPD size : 0
checksum : Valid
My NVM firmware cannot be updated, probably due to my newer version.
For those interested, you just need to modify the "config_i226.txt" file with your chipset ID codes and then run the command "nvmupdatew64e.exe -u -l -c config_i226.txt" in CMD.
Release note:
Fixes an issue in MDI lane swap handling that caused the P (positive) and N (negative) signal polarities to be swapped incorrectly.
Please note that the update has risks that it may fail, Station-Drivers and Fdrsoft cannot be held responsible in the event of a crash. !
Firmware 2.32 is included in the package, which you can download here Version 1Mo & 2Mo.
Intel-I226-V-NVM-Firmware/I226-V at main · BillyCurtis/Intel-I226-V-NVM-Firmware · GitHub
www.station-drivers.com/index.php/en/com....29-2.32/lang,en-gb/
Les utilisateur(s) suivant ont remercié: geneticsystem2013
Temps de génération de la page : 0.020 secondes
