Intel I226–LM/ V/ IT Lan Controllers Firmware Version 2.27
First firmware for the I226 series of network chipsets, version 2.27, dating from 2024
NVMUpdate version 1.41.3.1
Copyright(C) 2013 - 2024 Intel Corporation.
nvmupdatew64e.exe -i -l inventory.txt
Config file will not be read.
Inventory
[00:133:00:00]: Intel(R) Ethernet Controller I226-V
Flash inventory started.
Shadow RAM inventory started.
Flash inventory finished.
Vendor : 8086
Device : 125C
Subvendor : 1043
Subdevice : 8867
Revision : 6
LAN MAC : xxxxxxxxxxxx
Alt MAC : 000000000000
SAN MAC : 000000000000
ETrackId : 8000039D
SerialNumber : A0AD9FFFFFA10858
NVM Version : 2.35(2.23)
PBA : G23456-000
VPD status : Not set
VPD size : 0
checksum : Valid
Upon checking my chipset, I noticed that mine is newer and therefore doesn't require an update, but for those interested, here is the download link below.
For Windows & Linux
www.station-drivers.com/index.php/en/com...ion-2.27/lang,en-gb/
Inventory
Vendor : 8086
Device : 125C
Subvendor : 1043
Subdevice : 8867
Revision : 6
ETrackId : 8000039D
PBA : G23456-000
VPD size : 0
checksum : Valid
For Windows & Linux
- jumpy76
Re: Intel I226–LM/ V/ IT Lan Controllers Firmware Version 2.27
il y a 7 mois 2 semaines
Thank you very much! How to check the LAN firmware version? Any help on the flash? There are different bin and no executable file.
il y a 7 mois 2 semaines - il y a 7 mois 2 semaines
Hi, download the latest Intel Network Pack; the necessary files are in the NVM directory.
Intel Nework 31.1
www.station-drivers.com/index.php/en/com...ion-31.1/lang,en-gb/
Alternatively, run the command `nvmupdatew64e.exe -i -l inventory.txt`.
To update, simply change the firmware of the NVM directory in the Intel network pack and replace it with the one you want.
Intel Nework 31.1
