Intel Management Engine Interface (MEI/AMT) Version 2435.6.35.0
il y a 6 mois 1 semaine - il y a 6 mois 1 semaine
www.station-drivers.com/index.php/en/com...5.6.35.0/lang,en-gb/
Les utilisateur(s) suivant ont remercié: grimson, duttyend, fikotr74
- DRMiner
Re: Intel Management Engine Interface (MEI/AMT) Version 2435.6.35.0
SetupME.exe will not launch in Windows 11. Error Message: "This platform is not supported."
Yes because only for platforms with firmware 10.xx/11.xx/12.xx
- Almighty1
Did you post the correct version # as the screenshot says 2433.6.3.0
il y a 6 mois 1 semaineConfiguration
