chip Intel Management Engine Interface (MEI/AMT) Version 2418.6.12.0
  • SM-003
  • Portrait de SM-003
  • Moderator Global
  • Moderator Global
Re: Intel Management Engine Interface (MEI/AMT) Version 2418.6.12.0
il y a 9 mois 1 semaine
#3079
Après l'installation, vous avez un message pour rebooter ?
I haven't seen any.
Actually never for MEI driver updater at least.
System H/W Specifications
  • khealou
  • Portrait de khealou
il y a 9 mois 1 semaine - il y a 9 mois 1 semaine
#3081
Never had this problem before!
I have an HP ProBook 450 G7
PCI\VEN_8086&DEV_02E0   ;ME14.0 - CML
Firmware version: 14.1.72.2287
  • DRMiner
  • Portrait de DRMiner
#3082
There are two sets of drivers, signed with different certificates. Use the drivers in the "0" folder to manually install the drivers. The other drivers are signed with the Microsoft Windows PCA 2010 certificate, which is no longer compatible with secure boot.
P.S. The new Intel RST-VMD driver won't install for the same reason, but in that case, there are no alternative drivers signed with a different certificate.
Les utilisateur(s) suivant ont remercié: tistou77, duttyend, khealou
#3084
These new drivers are coming out for the new Z890 chipset (Meteor Lake), is that why? (Beta)
Tistou non pas besoin de redemarrer
  • tistou77
  • Portrait de tistou77
#3085
En effet c'était bien cela, avec les drivers dans le répertoire 0, ça fonctionne sans problème
Merci
Indeed that was it, with the drivers in directory 0, it works without problem
Thank you
