Golden Firmware gdfw
It's a Bootloader and is probably the firmware that's used when connect the device without a m.2 Drive for Firmware Updates etc..:
In case with Display LCD OLED they directly communicates with RTL9210 via bus I2C. All the images on the screen are stored in the Firmware. A separate controller is installed with customized for Display. So you need always Special Firmware.
For another chip ic communicates via bus with RTL9210. In this cases, there is a setting in the config:
PERIPH_API = 0x1
May be it should be on for RGB to, or a customized Firmware.
- Devices: In electronics, such as smartphones, routers, or other devices, Golden Firmware is used to ensure that the devices operate reliably.
- Software Development: In software development, Golden Firmware often serves as a foundation for future updates or modifications.
- Quality Assurance: It acts as a reference point for testing and quality assurance processes to ensure that all subsequent versions are stable.
PERIPH_API = 0x1
il y a 1 an 3 mois - il y a 1 an 3 moisMPTool mini need a config file to it´s : UTHSB_MPtool_Lite_Mini_1.ini and RTL9210B_CG_Lite.cfg
I will try the update directly with the MPTool mini utility because it does not require a configuration file and I think it does not overwrite the configuration of the LED lights, I will confirm this afternoon upon receipt of a new Sabret RTL9220 RGB box
I confirm, it does not erase the configuration of the original firmware but it fails on the update, too bad
[General]
UpdateSettings=771
PGSettings=257
ViewSettings=7
CSV=0
CfgSel=configure/RTL9210B_CG_Lite_0.cfg
FwFlashBinSel=UTNVME_B_v1.30.21.070622.bin
FwGoldenBinSel=gdfw/UTGDFW_B_v1.29.21.030422.bin
IsoSel=
ImgSel=
PreloadSel=
DiskPartition=GPT
DiskFormat=exFAT
DiskVolLabel=My USB
il y a 1 an 3 mois
Ok thanks but I'm not going to try because I'm afraid of losing the LEDs, I'll wait until I have the led.bin file
il y a 1 an 3 mois
yes I understand, maybe can ask her
sabrent.com/community/xenforum/general-discussion
il y a 1 an 3 mois
