  • waldyrdias@msn.com
  • Portrait de waldyrdias@msn.com
  • Membre
  • Membre
il y a 3 ans 3 mois
I updated my Unionsine MD202 with Realtek RTL9210B chipset firmware Version 1.32.49.140423, but macos won't mount the nvme drive. Could someone help me please.
The configuration is like this.
;Configure Start
U2PHY = 02 f4 9b e0 e1
U3PHY = 02 d4 09 00 d5 00 80
VID = 0xbda
PID = 0x9210
MANUFACTURE = "Unionsine"
SCSI_VENDOR = "        "
PRODUCT = "MD202"
SCSI_PRODUCT = "Unionsine MD202"
SERIAL = "N9D0AP042502"
DISK_HOTPLUG = 0x0
LED = 0x2
PINMUX1 = 0x0
PINMUX2 = 0x0
U2_MAXPWR = 0xfa
U3_MAXPWR = 0x0
ASPMDIS = 0x0
DISK_IPS_THRES = false
;EN_UPS = n/a
;PD = n/a
HW_LED_CFG = false
CUSTOMIZED_LED is 15 bytes = 0x80000081
CUSTOMIZED_LED = 07 00
SUSPEND_LED_OFF = 0x0
FAN = false
DIS_SHOW_EMPTY_DISK = false
FORCE_SATA_NORMAL_DMA = false
UART_DBG_PIN = 0x5
FINGER_PRINT_EN = false
DISCONN_FORCE_USB2 = 0x0
FORMAT_DISK = n
INC_SERIAL = false
;PARTITION: GPT, MBR
PARTITION = "GPT"
;FORMAT: NTFS, exFAT
FORMAT = "exFAT"
LABEL = "My USB"
  • Absent
il y a 3 ans 3 mois
did you try the default configuration with the realtek.....cfg file
Les utilisateur(s) suivant ont remercié: waldyrdias@msn.com
  • wade7575
  • Portrait de wade7575
il y a 3 ans 3 mois
What config file did you use,if you go to station drivers and type in RTL9210 and then start downloading every download for the RTL2910 chip you will that one has a massive amount of config files in it and then use file HIKSEMI_MD202.cfg to reflash your device.
I can't remember which download has it in it but one has a massive amount of those files in it,if you give me your email I don't mind emailing the file I have it save and it is the original file.
Les utilisateur(s) suivant ont remercié: admin, waldyrdias@msn.com
  • Membre
  • Membre
il y a 3 ans 3 mois
Yes, if I use the default configuration of realtek the files are in read mode, not allowing writing.
  • Membre
  • Membre
il y a 3 ans 3 mois
Could you send me please.
email: waldyr.dias@gmail.com
