S.M.A.R.T display not reading properly after updating (Fanxiang MD-86)
  • rococoricoco
  • Portrait de rococoricoco
Re: Realtek RTL9210(B) NVMe/USB 3.1 Controller firmware Version 1.34.29.011325
But I have previously upgraded to version 1.32.xxxxxx and nothing happened. The S.M.A.R.T display feature is working properly. Is it because I checked the PG to update? Because the dump file is a little bit different when I compare it before and after.
Re: S.M.A.R.T display not reading properly after updating (Fanxiang MD-86)
If the display isn't working at first, it's likely due to a disk compatibility issue and firmware.
  • Shonk   is the best person to answer this question.
  • rococoricoco
Hope he sees this post and can help. I’m very frustated with this.
  • Portrait de Laroldski
If your enclosure can't be fixed you may want to look at these enclosure's,I have had good luck with JEYI enclosure's plus you can purchase replacement PCB boards if the USB-C connector get's damaged.
This JEYI enclosure is better then most from what I have found because the backplate is around 2.5mm thick and carries away the heat better.
www.aliexpress.com/item/1005005977099067...arch%7Cquery_from%3A
These are replacement PCB boards you can get that are a direct fit.
www.aliexpress.com/item/1005008197399518...arch%7Cquery_from%3A
Dernière édition: il y a 1 an 7 mois par Laroldski. Raison: Forgot to include a second link.
  • halveeen
  • Portrait de halveeen
il y a 1 an 6 mois
Hello everyone, please I need help
My SSD Case "RTL9210B-CG  firmware version (22.1d / 1.34.29)" only works on USB 2.0 once its connected to usb3.1 I see the device in device manager but the SSD will not appear in file explorer
Original Dump
************************************************************** Device : [Port2] : Realtek RTL9210B-CG #0 ************************************************************** U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9210 MANUFACTURE : "Realtek" PRODUCT : "RTL9210B-CG" SERIAL : "012345679457" SCSI_PRODUCT : "RTL9210B-CG     " SCSI_VENDOR : "Realtek " LED : 0x02 DISK_IPS_THRES : 0x0a CUSTOMIZED_LED : 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00  UART_DBG_PIN : 0x05 ... Boot Mode : Flash FW Ver : 1.32.70 FW Build Date : 2023.07.06 IC Pkg Type : PCIE/SATA Disconn_ForceUSB2 : false ...
Truncated for brevity...I removed all that had n/a
New firmware installed today dump
************************************************************** Device : [Port2] : Realtek RTL9210B-CG #0 ************************************************************** U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9210 MANUFACTURE : "Realtek" PRODUCT : "RTL9210B-CG" SERIAL : "012345679458" SCSI_PRODUCT : "RTL9210B-CG     " SCSI_VENDOR : "Realtek " USB_SELF_PWR : n/a DISK_HOTPLUG : n/a LED : n/a PINMUX1 : n/a PINMUX2 : n/a U2_MAXPWR : n/a U3_MAXPWR : n/a ASPMDIS : n/a PCIE_REFCLK : n/a DISK_IPS_THRES : n/a SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00  SUSPEND_LED_OFF : n/a FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : 0x05 FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a FORCE_PORT_TYPE : n/a BCDDEVICE : n/a SUSPEND_DISK_OFF : n/a SCSI_WB_PIN : n/a CUSTOMIZED_FEATURE : n/a PERIPH_API : n/a RAID_CFG : n/a Boot Mode : Flash FW Ver : 1.34.29 FW Build Date : 2025.01.13 IC Pkg Type : PCIE/SATA UUID : n/a Disconn_ForceUSB2 : false
I don't know if I am posting this in the right channel, just signed up today...but yh I need help figuring why my SSD does not work on USB3 only USB 2
