Help needed for Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.33.5
- leon22heart
il y a 1 mois 1 semaine - il y a 1 mois 1 semaine
Hello to all. I have a Realtek usbc nvme case adapter (with fan) that came with the firmware version 1.33.5 with date 2023.10.06 . I saw that this firmware is not shared by anyone in the forum so i wanted to ask if it is possible to dump the firmware in a non destructive way ( desoldering the chip ) . Below i include some photos .
Les utilisateur(s) suivant ont remercié: admin, duttyend
Re: Help needed for Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.33.5
There is no tools to dump Realtek firmware
I dumped a RTL9201R a while back by removing the chip
the only way to flash it back on is via a programmer
there doesnt seem to be a simple way to make a firmware thats flashable
with Realtek's flasher
tbh there's no real point dumping it we have plenty of firmware's for the RTL9210B
with 1.33.98 being the latest
just dump the device info (nvram) with the flasher
and clone them settings before flashing the latest firmware
Les utilisateur(s) suivant ont remercié: duttyend, leon22heart
- leon22heart
Thank you for the info . It was probably your post i saw that made me question the viability of dumping this firmware without manual intervention. So i guess there is no need for such firmware .One question though , is there a guide pointing to flashing realtek firmware ? Jmicron and vli were the only ones i have tried in the past and in hdd cases that were missing the fan . My main fear is that fan will stop working.
PS Is this guide a valid one github
- leon22heart
Flashed the latest firmware , everything works well . I include the config file for anyone wanting a reference.
VID = 0xbda
PID = 0x9210
MANUFACTURE = "Realtek"
PRODUCT = "USB3.1 USB Device"
SERIAL = "012345678904"
SCSI_PRODUCT = "RTL9210B-CG"
SCSI_VENDOR = "Realtek"
USB_SELF_PWR = 0x0
DISK_HOTPLUG = 0x0
LED = 0x2
PINMUX1 = 0x0
PINMUX2 = 0x0
U2_MAXPWR = 0x0
U3_MAXPWR = 0x0
ASPMDIS = 0x0
PCIE_REFCLK = 0x0
DISK_IPS_THRES = 0xf
SWR_1_2V = 0x0
EN_UPS = 0x0
PD = 0x0
CUSTOMIZED_LED = false
SUSPEND_LED_OFF = 0x3
FORCE_USB_SPEED = 0x0
FORCE_PCIE_SPEED = 0x0
EN_U1U2 = 0x0
FORCE_USB_QUIRK = 0x0
FORCE_PCIE_QUIRK = 0x0
FAN = 0x0
DIS_SHOW_EMPTY_DISK = 0x1
FORCE_SATA_NORMAL_DMA = 0x0
UART_DBG_PIN = 0x5
FINGER_PRINT_EN = 0x0
RM_INTERNAL_RD = 0x0
HS_AUTO_SWITCH = 0x0
UART_BAUD_RATE = 0x0
CUSTOMIZED_DISK_IDENTIFY = 0x0
HW_LED_CFG = 0x0
CDROM_CFG = false
SUPPORT_HID = 0x0
LATE_INIT_DISK = 0x0
SCSI_WP_PIN = 0x0
SD_MMC_TYPE = 0x0
FORCE_PORT_TYPE = 0x0
BCDDEVICE = 0x0
SUSPEND_DISK_OFF = 0x0
SCSI_WB_PIN = 0x0
CUSTOMIZED_FEATURE = 0x0
PERIPH_API = 0x0
RAID_CFG = 0x0
