ssd ASMedia ASM1053 Firmware Collection
il y a 2 mois 2 semaines - il y a 2 mois 2 semaines
#4205
I Decided to flash all of my old ASM1053's from Seagate Enclosures to the best firmware
which seems to be this as it's the most feature complete
130107_91_7D_01 UASP NO TRIM Drive ID Passthrough
If you get problems with flashing failing you can either short pins 1+2 with small tweezers to boot into the safe rom
built into the chip,unshort when the pc makes the usb connected sound
or just unplug it and plug back in and try again
you have to be on the safe rom if you want to backup your current firmware
ASM1053 Firmware's
120720_90_A9_05 UASP NO TRIM (From Seagate BACKUP+)
130107_91_7D_02 UASP NO TRIM
130409_11_DA_01 NO UASP NO TRIM
130423_11_AC_04 NO UASP NO TRIM
mega.nz/file/9iBA3YoS#Ey3qhpgE5wL5ZrEi9J...hZqi-TTyr8NRTSnWAf2Y
Temps de génération de la page : 0.073 secondes
