ssd Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.33.98.090324
il y a 3 mois 1 semaine - il y a 3 mois 1 semaine
#4120
The update allows an increase in speeds both in writing and in reading and works perfectly on my Asus TUF A1 it is rare to see a firmware bring so much difference
The gains made are due to improved support for certain SSDs.
www.station-drivers.com/index.php/en/com...8.090324/lang,en-gb/
Les utilisateur(s) suivant ont remercié: Shonk, AOnurY, leon22heart
Re: Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.33.98.090324
#4122
Enclosure no name with SSD980Pro 1To
  • Portrait de Shonk
#4123
thanks i have been wondering when we will get 1.33.98 that AOnurY mentioned a while ago
did someone dump it or an oem release it?
#4124
It is a manufacturer who publishes it
#4125
On my side better compatibility and therefore better performances with certain SSD no name because those of big brands the performances are similar.
Have you also noticed differences
