Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.33.98.090324
il y a 3 mois 1 semaine - il y a 3 mois 1 semaine
The update allows an increase in speeds both in writing and in reading and works perfectly on my Asus TUF A1 it is rare to see a firmware bring so much difference
The gains made are due to improved support for certain SSDs.
www.station-drivers.com/index.php/en/com...8.090324/lang,en-gb/
Les utilisateur(s) suivant ont remercié: Shonk, AOnurY, leon22heart
Re: Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.33.98.090324
il y a 3 mois 1 semaineConfiguration
thanks i have been wondering when we will get 1.33.98 that
AOnurY
mentioned a while ago
did someone dump it or an oem release it?
It is a manufacturer who publishes it
On my side better compatibility and therefore better performances with certain SSD no name because those of big brands the performances are similar.
Have you also noticed differences
Temps de génération de la page : 0.084 secondes
