ssd Asmedia ASM2464 NVME/USB 4.x Controller Firmwares
il y a 11 mois 3 semaines
#2707
I can't help you because I have a white LED on the case that flashes when the SSD is active
  • nadja75
  • Portrait de nadja75
#2712
Thank you anyway. My only hope is that the Aliexpress seller will be able to recover the customized firmware, otherwise I will have to buy another identical unit to be able to read the firmware from the flash and then rewrite it on this non-working one. Another solution would be to be able to rewrite the memory parameters as they were in the original, in fact in the files I have attached it is possible to see two tables in hexadecimal, which are nothing other than the contents of the ini file.
  • Portrait de Laroldski
#2714
I would like to give you a word of advice and that I have learnt the hard way to always make a back up copy of firmware right away and keep it in a safe place.
I found that when it comes to enclosure's and the configure files are the most important thing to keep a copy of the original because from I have found a lot of the manufacturer's of enclosure's it's next to impossible to get firmware or configure files,all I can say is I'm very grateful we have station drivers.
#2715
@nadja75 I don't know if you tried looking up Hagibis online to find their official website,I did and will link it to you because I be you will have better luck getting the firmware that way,I can also tell you for sure that I have had better luck with Yottamaster and JEYI giving me firmware when I asked them for it threw their main websites and not threw aliexpress.
www.hagibis.com.cn/usb4-m2-nvme-ssd-enclosure-p00286p1.html
  • nadja75
#2719
Laroldski post=2715 userid=13439@ nadja75 Non so se hai provato a cercare Hagibis online per trovare il loro sito ufficiale, l'ho fatto e te lo collegherò perché immagino che avrai più fortuna a ottenere il firmware in questo modo, posso anche dirti con certezza che Ho avuto più fortuna con Yottamaster e JEYI che mi hanno fornito il firmware quando ho chiesto loro di lanciarlo sui loro siti Web principali e non su aliexpress.
Thanks, I will try to follow this path too to solve the problem. I will keep you informed of any news.
