hdd2 Jmicron JMS-583 NVMe/USB 3.1 Controller firmware Version 0.2.1.4
il y a 1 an 7 mois
#1499
www.station-drivers.com/index.php/en-us/...-0.2.1.4/lang,en-us/
Les utilisateur(s) suivant ont remercié: Tom, dvampoulis
  • Lin
  • Portrait de Lin
Re: Jmicron JMS-583 NVMe/USB 3.1 Controller firmware Version 0.2.1.4
il y a 1 an 7 mois
#1502
Is there information about what is new in this firmware?
il y a 1 an 7 mois
#1507
sorry no Jmicron can communicate on the release
  • nstorm
  • Portrait de nstorm
#1514
I've dumped and submitted this firmware from recently purchased case by unnamed China brand. Works fine so far, getting ~995 MB/s seqential speeds, both read & write with some cheap DRAM-lesss MAP1202 based drive.
Don't have the changelog for it either. JMicron aren't good at even releasing firmwares for their chips for public.
PS: @admin, I've noticed that file are not placed under JMS-583 caterogy ( www.station-drivers.com/index.php/en/com...ntroller/lang,en-gb/ ), probably should go there as other versions?
Ryzen 7 7700X / GIGABYTE B650M GAMING X AX / 64Gb DDR5-5600/36-36-36-76 / PNY RTX 4090 XLR8 24Gb / XPG Gammix S70 Blade 2Tb, Digma Meta G2 1Tb / GIGABYTE AORUS P850W
il y a 1 an 7 mois
#1517
ok i correct it now thank you
Les utilisateur(s) suivant ont remercié: nstorm
