Jmicron JMS583 Sata USB 3.1 Controller Firmware Version 133.0.1.00.06
- rvail
This firmware update software contains remnants of the person that last used it, when running the "JMMassProd_v1_16_15_12.exe" executable file.
There is no included readme.txt file to explain which of the 7 different .bin files would be appropriate for upgrading an existing JMS583 device. An existing firmware is detected as "02.01.03", so "JMS578_STD_v00.02.01.05_Self Power.bin" would appear to be the correct update, but not really sure.
Les utilisateur(s) suivant ont remercié: hoviliy845
Re: Jmicron JMS583 Sata USB 3.1 Controller Firmware Version 133.0.1.00.06
il y a 1 an 7 mois
This is an old release adding JMS583_FW_133_01_00_02, JMS583_FW_133_01_00_03 and JMS583_FW_133_01_00_06.
I have currently version v2.01.03 which is dated April 22, 2022.
When selecting v2.01.05 it tells me "FW file not match."
- Absent
Hi yes I preferred to put the firmware on the latest pack because the update is not included in the original package
Tom Yes because some version are not compatible with each other why?
I prefer to propose it if necessary
il y a 1 an 7 mois - il y a 1 an 7 moisBecause the 2.01.05 is for the JMS578 according to the filename (JMS578_STD_v00.02.01.05_Self Power).Tom Yes because some version are not compatible with each other why?
- Absent
il y a 1 an 7 moisConfiguration
