- Silverian
3 months 15 hours ago
Hello fiko,
I didn't test that specific version yet, but I have tested one of the HP versions that you shared days ago 6.0.10016.1. Let me give it a try and I will reply back.
- Silverian
3 months 12 hours ago - 2 months 4 weeks ago
fiko
I have tested the suggested 6.0.10013.1 ALL OEM from the Microsoft Windows Catalog and the same BSOD popped out unfortunately .
This is the WinDbg .dmp log:
And...
Please allow me to clarify this is the first time I used Driver Fusion, I have been using Iobit Driver Booster for about 5 years. What would you suggest at this point?
[color=#1e1e1e]*******************************************************************************
* Bugcheck Analysis *
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000b50, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff800d5eb3a47, address which referenced memory
Debugging Details:
*** WARNING: Unable to verify timestamp for RTKVHD64.sys
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 2593
Key : Analysis.Elapsed.mSec
Value: 2614
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 1078
Key : Analysis.Init.Elapsed.mSec
Value: 4164
Key : Analysis.Memory.CommitPeak.Mb
Value: 82
Key : Analysis.Version.DbgEng
Value: 10.0.29617.1000
Key : Analysis.Version.Description
Value: 10.2604.29.1 amd64fre
Key : Analysis.Version.Ext
Value: 1.2604.29.1
Key : Bugcheck.Code.LegacyAPI
Value: 0xa
Key : Bugcheck.Code.TargetModel
Value: 0xa
Key : Dump.Attributes.AsUlong
Value: 0x21808
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0x0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Value: Dump completed successfully.
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: AV_RTKVHD64!unknown_function
Key : Failure.Exception.IP.Address
Value: 0xfffff800d5eb3a47
Key : Failure.Exception.IP.Module
Value: nt
Key : Failure.Exception.IP.Offset
Value: 0x2b3a47
Key : Failure.Hash
Value: {8427c922-ba45-a12b-e45a-4e0138637121}
Key : Faulting.IP.Type
Value: Paged
Key : Hypervisor.Enlightenments.ValueHex
Value: 0x749fcf96
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 1
Key : Hypervisor.Flags.ApicEnlightened
Value: 1
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 0
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 1
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 0
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 1
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 1
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 0
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 1
Key : Hypervisor.Flags.Phase0InitDone
Value: 1
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 1
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 38277359
Key : Hypervisor.Flags.ValueHex
Value: 0x24810ef
Key : Hypervisor.Flags.VpAssistPage
Value: 1
Key : Hypervisor.Flags.VsmAvailable
Value: 1
Key : Hypervisor.RootFlags.AccessStats
Value: 1
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 1
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 1
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 1
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 1
Key : Hypervisor.RootFlags.MceEnlightened
Value: 1
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 1
Key : Hypervisor.RootFlags.Value
Value: 1015
Key : Hypervisor.RootFlags.ValueHex
Value: 0x3f7
Key : WER.System.BIOSRevision
Value: 15.55.0.0
BUGCHECK_CODE: a
BUGCHECK_P1: b50
BUGCHECK_P2: 2
BUGCHECK_P3: 1
BUGCHECK_P4: fffff800d5eb3a47
FILE_IN_CAB: 083026-15734-01.dmp
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
Kernel Generated Triage Dump
FAULTING_THREAD: [/color][color=#0000ff]ffffd7897df95080
[/color][color=#1e1e1e]WRITE_ADDRESS: fffff800d6bc54d8: Unable to get MiVisibleState
0000000000000b50
BLACKBOXBSD: 1 ([/color][color=#0000ff]!blackboxbsd[/color][color=#1e1e1e])
BLACKBOXNTFS: 1 ([/color][color=#0000ff]!blackboxntfs[/color][color=#1e1e1e])
BLACKBOXPNP: 1 ([/color][color=#0000ff]!blackboxpnp[/color][color=#1e1e1e])
BLACKBOXWINLOGON: 1 ([/color][color=#0000ff]!blackboxwinlogon[/color][color=#1e1e1e]) ([/color][color=#0000ff]!blackboxwinlogonnotify[/color][color=#1e1e1e])
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
IP_IN_PAGED_CODE:
nt!KeCancelTimer+67
fffff800`d5eb3a47 f00fba2f07 lock bts dword ptr [rdi],7
STACK_TEXT:
ffff8080`8360d128 fffff800`d62c04e9 : 00000000`0000000a 00000000`00000b50 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
ffff8080`8360d130 fffff800`d62bb7a8 : 00000000`00000000 00000000`00000000 00000000`00000b50 00000000`00000000 : nt!KiBugCheckDispatch+0x69
ffff8080`8360d270 fffff800`d5eb3a47 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff800`d5ed447b : nt!KiPageFault+0x468
ffff8080`8360d400 fffff804`d65303d2 : 00000000`00000000 fffff804`d66f00d0 00000000`00000000 ffffd789`7e736bf0 : nt!KeCancelTimer+0x67
ffff8080`8360d4a0 00000000`00000000 : fffff804`d66f00d0 00000000`00000000 ffffd789`7e736bf0 ffffd789`7dce0bc0 : RTKVHD64+0x403d2
SYMBOL_NAME: RTKVHD64+403d2
MODULE_NAME: [/color][color=#0000ff]RTKVHD64
[/color][color=#1e1e1e]IMAGE_NAME: RTKVHD64.sys
STACK_COMMAND: [/color][color=#0000ff].process /r /p 0xffffd789794aa040; .thread /r /p 0xffffd7897df95080 ; kb
[/color][color=#1e1e1e]BUCKET_ID_FUNC_OFFSET: 403d2
FAILURE_BUCKET_ID: AV_RTKVHD64!unknown_function
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {8427c922-ba45-a12b-e45a-4e0138637121}
Followup: MachineOwner
---------[/color]
And...
Last edit: 2 months 4 weeks ago by Silverian. Reason: Added WinDbg .tmp code
- fikotr74
3 months 5 hours ago - 3 months 4 hours agofiko ,
And...
Is your system installed as an old MBR or UEFI? Because many current drivers now only support UEFI. If it's MBR, I think you can only use MBR-supported drivers.
I'm experiencing the same problem on a PC that doesn't support UEFI. That's the last thing that came to my mind.
I use "Driver Genius" and "Driver Booster".
Last edit: 3 months 4 hours ago by fikotr74.
- josefrancklin
2 months 4 weeks ago - 2 months 4 weeks ago
- I am not not sure why, but even if hardware ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0295&SUBSYS_103C8615 is present inside every HDXHAPHPNB.inf driver I have tested (supposed to be compatible), I am still getting the BSOD.
Hi Silverian,
Last edit: 2 months 4 weeks ago by josefrancklin. Reason: Add information
- Silverian
2 months 4 weeks agoMy Windows 11 NVME is formated with GPT partition using entirely UEFI, CSM is disabled and Secure Boot is enabled on my BIOS.fiko ,
And...
Time to create page: 0.030 seconds
