JMS583 chip
Re: JMS583 chip
(QUMOX 256Go)
it depends on the SSD if the transfer rate is constant or not
  • Max88
  • Max88's Avatar
  • Poster
  • Poster
Re: JMS583 chip
4 years 3 weeks ago
So if it works, doesn't it matter that I passed firmware 0209 first and then 20.05.00.01?I don't wish I ruined the enclosure
Re: JMS583 chip
4 years 3 weeks ago
No need to update, rather check the USB 3.2 connection if it is in USB 3.2, I will rather think where the problem is
I will show you if necessary how to check if the port where the Nvme / USB box is connected is in USB 3.2
  • Max88
  • Max88's Avatar
  • Poster
  • Poster
Re: JMS583 chip
4 years 3 weeks ago
Yes but now I have already updated twice as previously written. What do I do now? Do I need to downgrade?
Re: JMS583 chip
4 years 3 weeks ago
Check your port if it is USB 3.2 to be able to take advantage of the fastest transfer rate
