Sound volume unnecessarily high
  • rvail
  • rvail's Avatar Topic Author
5 months 1 week ago
Sir: Please adjust the audio volume on the little video ad on the lower right that resists being disabled. The audio volume is unnecessarily loud.Thanks.
Re: Sound volume unnecessarily high
5 months 1 week ago
Hi, I can't do that, but you can disable it via your browser's settings menu.
  • erpster96
  • erpster96's Avatar
5 months 1 week ago
what kind of computer are you using and what web browsers do you have?
I'm not experiencing that kind of volume problem on many of my desktop & laptop PCs
  • rvail
5 months 1 week ago
Windows 10 64 bit (build 19045.7417)., Google Chrome Browser. Grok suggested the Chrome extension "QuietWeb", which I'm currently trying out.
Note: Station-Drivers is the only problematic web site with booming loud audio. Any other web site has audio volume that is okay.
Admin said: "Hi, I can't do that, but you can disable it via your browser's settings menu. "
However, I'm not seeing the setting that would sisable pop-up video audio for one particular web site.
Time to create page: 0.020 seconds
