6 months 2 weeks ago
Yes, as Shonk said, some motherboards have the AQC113 connected in X3 due to the limitation of the PCI-E lanes.
  • SystemFailure
  • SystemFailure's Avatar
6 months 20 hours ago
Hello
I have a TP-Link TX401 rev 2.0 network adapter (AQC113 chipset). During some downloads, the network adapter stops working. I have to restart it from the Windows diagnostics.
I updated the driver to version 3.1.11.0 and the firmware to version 1.5.45.
Everything went smoothly except that the network adapter now indicates that the cable is disconnected.
How can I revert to a working firmware version? (I ran Kickstart2 before flashing and got version 1.5.38.)
c:\Users\Laurent\Downloads\40d1b2d8AQC113update+1.45(station-drivers.com)>kickstart2.exe
kickstart2 x86_64-w64-mingw32-5.0-3-gfaad6c70
Connected to device 'NDISIO:04C0-005:00.0'
Chip reset completed (boot from flash). Time: 100 ms
Loaded bundle: 1.5.38
The Loaded bundle is now 15.45, but it's not working.
How do I revert to the previous version?
Thanks
  • Patator
  • Patator's Avatar
6 months 15 hours ago - 6 months 15 hours ago
I have the same issue. Latest driver, trying to make it work in a Pcie3 x1.
Flashed to 1.5.45.
Both leds where off. In the windows event viewer, I could see :
Aquantia AQtion Network Adapter : Ioctl function call unknown.
Marvell AQtion 10Gbit Network Adapter #2 : Network link is lost.
Then I flashed back to 1.5.38 and the issue persist. Did I bricked the card ?
Last edit: 6 months 15 hours ago by Patator.
  • SystemFailure
6 months 15 hours ago - 6 months 14 hours ago
I have solved my problem
I used the programs from version 1.5.45, but I also restored the files from version 1.5.38, which are located here:
I downloaded version 1.5.38  www.station-drivers.com/index.php/fr/com...own/6142/lang,fr-fr/
( www.station-drivers.com/index.php/fr/com...n-1.5.38/lang,fr-fr/ )
I copied the two files of version 1.5.38 into the program directory of version 1.5.45
- ATL2-8.0.1_agent_SIGN.clx
- AQC113-DirtyWake-Swap_Bx-1.5.38_bdp_aqsign.clx -> rename this file by : AQC113-DirtyWake-Gen3_MemVDD07V_HysterON-1.5.45_aqsign.clx
into the program directory of version 1.5.45 and ran the flash startprg.bat file again.
I shut down the PC, unplugged the power supply and network cable, and then plugged everything back in.
It's working again. I left driver version 3.1.11.0
Last edit: 6 months 14 hours ago by SystemFailure.
  • Patator
  • Patator's Avatar
Already tried that.
This is the output of kickstart2.exe
Chip reset completed (boot from flash). Time: 95 ms
1.5.38 bundle is loaded, but still nothing, no leds also, when I plug the cable.
