  • 's Avatar
  • User
  • User
Intel WIFI drivers 23.0.0.18 works for me.
ibb.co/5RGh7kQ
HWID
PCI\VEN_8086&DEV_43F0&SUBSYS_00748086&REV_11
That's strange becuse yours is AX201, not AX211/AX411/BExxx
neither the HW id you shared is enlisted inside the INF
Did you manually forcefeed the INF via DM?
Just realised, you're talking about different driver version 23.0.0.18, not the v23.0.5.7
I personally did not try 23.0.0.18 yet as it was only available here but the discussion earlier seems to indicate it wasn't working for 99% of the people and I have an AX210 so I am surprised it worked on an AX201 as the AX200/AX201 are the same specs as in WiFi6 other than the 201 being CNVi and the AX210/AX211 are the same spec as in WiFi6E except the AX211 is for CNVi systems.  xx0 means it's for regular sysems and xx1 means it's for CNVi systems.
Last edit: 3 years 2 months ago by .
  • mdm
  • mdm's Avatar
  • LIBERATE TUTE ME EX INFERIS
No support for AX210 in 23.0.5.7 either, but there is for AX200..??
Tried last one23.0.0.18 too, no go!
But BT 23.0.0.10 does work! (23.0.0.6 did not)
Last edit: 3 years 2 months ago by mdm.
  • 's Avatar
  • User
  • User
I just tried  www.station-drivers.com/index.php/en-us/...x-whql?start=10#1732 on AX210 and just like you, not working.   BT 23.0.0.10 does work on the AX210 as it worked for me when I tried it yesterday before posting the link for the folders version.  Never tried 23.0.0.6 since it was older than the newest thing that worked.
  • Tom's Avatar
I suggest to stay away from package 23.0.0.18, this is in my opinion a Beta version built in July 2023.
Package is 23.0.5.7 is good to go for WiFI, but missing the following folders with their respective Product and Subsystem IDs when extracting "Intel Bluetooth.msi" from the Bluetooth folder.
Not included:
JFP
VID_8087&PID_0AAA&REV_0000
VID_8087&PID_0AAA&REV_0001
VID_8087&PID_0AAA&REV_0002
SDP
VID_8087&PID_0AA7
STP
VID_8087&PID_0A2A
THP
VID_8087&PID_0025&REV_0001
VID_8087&PID_0025&REV_0002
Last edit: 3 years 2 months ago by Tom.
  • Tom's Avatar
This package ain;t compatible with AX211
This is partly true:
211AX and A411AX devices with VEN_8086&DEV_7A70 and VEN_8086&DEV_7AF0 are not supported in this driver, but 211AX and 411AX devices with VEN_8086&DEV_7E40 are supported.
