#960
Pour: Intel(R) Ethernet Connection I225-LM (Code ID 15F2) & Intel(R) Ethernet Connection I225-V (Code ID 15F3)
Date du firmware: 2023/04/24
Origine: Lenovo
Release note:
Important update
New function or enhancement
Correction to existing function
Ce firmware peut-il résoudre les problèmes liés aux dysfonctionnements du I225 Rev 1.x comme la limitation du débit a 1Gbs au lieu de 2.5Gbs ou l'instabilité du débit  ou voir d'autres problèmes ?
Procédure de mise a jour:  www.station-drivers.com/index.php/en-us/...irmware-version-1-89
www.station-drivers.com/index.php/en-us/...5Gb-Lan)/lang,en-us/
Last edit: 1 year 11 months ago by admin.
The following user(s) said Thank You: Jodragons
  • Adelina
  • Adelina's Avatar
#962
I will be the first hero, return
I use ASUS motherboard i225-v after the update is completed, the network card is correctly captured
but can't connect
may be a mismatch
I have followed the steps to backup the dump
But I don't know how to restore the command at present
Also ask the author to provide how to restore and repair the firmware
Thanks
2023/05/03 09.23pm update Just turned on the computer again, and it can be connected normally. The problem lies in the rotten network cable, there is a problem with the contact, just change it Will update if there is any problem
Last edit: 1 year 11 months ago by Adelina.
#964
hi,
Perfect, thanks for the feedback
restore it I will put how on the article
  • Adelina
  • Adelina's Avatar
#965
Just looked at the restore command
I also tried to replace NVM\xxxx.bin yesterday
But it shows that the verification failed, I forgot to take a screenshot
I don't know if the firmware will be verified for safety now
Currently 1.89 works, I can't try any further
I have to wait for other friends, it is useful to restore the command in the feedback
error message
Shared Flash image update FAILED! FLASHimage authentication failed
1.89
1. Update PHY FW to 4C08_878D
2. Update EFI LAN driver to 0.10.04
3. Resolve HSD 1309832919 Not enumerated after WR cycle
#966
Thank you for the info me personally I do not encounter any problem for the moment, do not hesitate to leave comments
Thanks also for the release note
