  • sdefrwggerg
  • sdefrwggerg's Avatar
Golden Firmware gdfw
It's a Bootloader and is probably the firmware that's used when connect the device without a m.2 Drive for Firmware Updates etc..:
  • Devices: In electronics, such as smartphones, routers, or other devices, Golden Firmware is used to ensure that the devices operate reliably.
  • Software Development: In software development, Golden Firmware often serves as a foundation for future updates or modifications.
  • Quality Assurance: It acts as a reference point for testing and quality assurance processes to ensure that all subsequent versions are stable.
Never purchase cases that contain plastic case. To ensure effective heat dissipation from the disk and RTL Chip, the case should be constructed from solid metal. This applies universally, regardless of the Chipset be it RTL, JMS, or ASM. This guarantees stable operation without overheating or unexpected shutdowns. In addition to the SSD, heat must also be dissipated from the RTL9210 chip.
In case with Display LCD OLED they directly communicates with RTL9210 via bus I2C. All the images on the screen are stored in the Firmware. A separate controller is installed with customized for Display. So you need always Special Firmware.
For another chip ic communicates via bus with RTL9210. In this cases, there is a setting in the config:
PERIPH_API = 0x1
May be it should be on for RGB to, or a customized Firmware.
Last edit: 1 year 3 months ago by sdefrwggerg.
  • sdefrwggerg
I will try the update directly with the MPTool mini utility because it does not require a configuration file and I think it does not overwrite the configuration of the LED lights, I will confirm this afternoon upon receipt of a new Sabret RTL9220 RGB box
I confirm, it does not erase the configuration of the original firmware but it fails on the update, too bad
MPTool mini need a config file to it´s : UTHSB_MPtool_Lite_Mini_1.ini and RTL9210B_CG_Lite.cfg
[General]
UpdateSettings=771
PGSettings=257
ViewSettings=7
CSV=0
CfgSel=configure/RTL9210B_CG_Lite_0.cfg
FwFlashBinSel=UTNVME_B_v1.30.21.070622.bin
FwGoldenBinSel=gdfw/UTGDFW_B_v1.29.21.030422.bin
IsoSel=
ImgSel=
PreloadSel=
DiskPartition=GPT
DiskFormat=exFAT
DiskVolLabel=My USB
Ok thanks but I'm not going to try because I'm afraid of losing the LEDs, I'll wait until I have the led.bin file
  • sdefrwggerg
yes I understand, maybe can ask her sabrent.com/community/xenforum/general-discussion
Yes, if you want, because that would solve the update problems for those who have a box with LEDs.
