If that ends up being the case which i think it will be
lets say it comes with
250528_85_02_04
i will hex compare it to
250528_85_00_00
and hopefully its just a few bytes changed in the bin rather than a whole module inserted
i can then duplicate it on newer firmwares
Edit interesting i have never noticed that hagibis firmware before here its 02_03 rather than 02_04 but wll try it now
maybe it goes up by the number of releases for that build
e.g. 250528_85_02_05
I wonder where it came from
250528_85_02_04
250528_85_00_00
I have tested AS_USB4_231005_85_02_03.bin
Its not compatible with my Micron 3400 2TB
AS_USB4_240417_85_02_04 .bin was fine with it
The lights work blue for pcie green for usb 3.x
The light works always green no matter the interface with 85_00_00
I have also ruled out the config or settings for the flasher its 100% a custom firmware for the enclosure
It cant be reverse engineered its a totally custom build almost the whole of the bin is different compared to
AS_USB4_231005_85_02_03.bin & AS_USB4_231005_85_00_00.bin
I will just release what ever build is on the Hagibis when it comes hopefully its atleast a 2025 build
Can you remember where this came from admin?
You can compare it with the original one.
Asmedia ASM2464 NVME/USB 4.x Controller Firmware Version 231005_85_02_03
from the manufacturer's website
any chance of getting a link to the page i cant find it
