  • pt83
  • pt83's Avatar
Yes I just tried to flash one of them which send to safemode, I can just reformat to make them normal again.
The info I showed is before flashing.
Last edit: 2 years 1 month ago by pt83.
I have 8 Orico RTL9201B's Orico are very lazy and hardly ever use different firmware or nvram
here's the factory config from one of mine
it should be fine on yours also
mega.nz/file/JnZgyIwK#cxP9AVtktztyI6yNun...2rTZZdX1WkiCnmiCrjzo
Last edit: 2 years 1 month ago by Shonk.
The following user(s) said Thank You: pt83
  • pt83
  • pt83's Avatar
2 years 1 month ago
Its no good reading it now you have to read it before ever flashing it
the second one is running the goldenfirmware (safemode firmware)
as you havnt added complete info is my guess
This is the original info
************************************************************** Device : [Port6] : Realtek RTL9210 NVME #0 ************************************************************** U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9210 MANUFACTURE : "Realtek" PRODUCT : "RTL9210" SERIAL : "012345678905" SCSI_PRODUCT : "RTL9210 NVME    " SCSI_VENDOR : "Realtek " DISK_HOTPLUG : n/a LED : 0x01 PINMUX1 : n/a PINMUX2 : n/a U2_MAXPWR : n/a U3_MAXPWR : n/a ASPMDIS : n/a PCIE_REFCLK : n/a DISK_IPS_THRES : n/a SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : n/a SUSPEND_LED_OFF : n/a FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : 0x05 FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a FORCE_PORT_TYPE : n/a BCDDEVICE : n/a SUSPEND_DISK_OFF : n/a SCSI_WB_PIN : n/a CUSTOMIZED_FEATURE : n/a Boot Mode : Flash FW Ver : 1.32.901 FW Build Date : 2022.12.07 IC Pkg Type : PCIE UUID : n/a Disconn_ForceUSB2 : false
no thats after you have flashed it and its running the golden firmware as you messed something up
the info has to be pulled before you ever mess with it
read up i have provided you with a orico config file
  • pt83
  • pt83's Avatar
Your config worked. Thank you!!!. btw that is before I do flashing. Unless the manufacturer f*ckup my box, it is not me changing any info.
