  • p33994451
  • p33994451's Avatar
3 years 1 month ago - 3 years 1 month ago
I'd like to ask if anyone has purchased a similar version that comes with a fan?
www.lazada.com.ph/products/m2-nvme-ngff-...XajTE.364bnXajnXajTE
[img
The original firmware was 1.32.16, and I flashed the latest version, 1.32.87. Originally, the fan would spin, but now it doesn't. I asked the seller, and they said that this temperature-controlled fan is not related to the firmware; it should activate when the temperature is high. However, I feel like it might not be the case.Below is my original configuration file.
U2PHY : 02 f4 9b e0 e1
U3PHY : 02 d4 09 00 d5 00 80
PRODUCT : "RTL9210B-CG"
SERIAL : "012345680151"
SCSI_PRODUCT : "RTL9210B-CG     "
DISK_HOTPLUG : 0x00
LED : 0x03
PINMUX1 : 0x00000000
PINMUX2 : 0x00000000
DISK_IPS_THRES : 0x05
CUSTOMIZED_LED : n/a
FAN : 0x00000001
DIS_SHOW_EMPTY_DISK : 0x01
FW Ver : 1.32.16
FW Build Date : 2023.01.09
IC Pkg Type : PCIE/SATA
**The configuration file after the update is as follows
Device : [Port19] : Realtek RTL9210B-CG #0
SERIAL : "012345680152"
DISK_HOTPLUG : n/a
LED : 0x03
DISK_IPS_THRES : n/a
EN_U1U2 : 0x01
UART_DBG_PIN : n/a
FW Ver : 1.32.87
FW Build Date : 2023.08.29
I've already tried adjusting the fan settings, hoping it would start working after the firmware update, but the values still show as "n/a" after the update. I hope someone who has purchased a similar device or other friends can help me out! Thanks!
Last edit: 3 years 1 month ago by p33994451.
3 years 1 month ago
It is possible that it is not linked to the firmware and that it has a CTN or a probe, you will have to check with a hair dryer to see if it triggers
  • sdefrwggerg
  • sdefrwggerg's Avatar
Enclosure with or without fan    On=0x1     Off=0x0
FAN = 0x0
In your new Settings you turn Fan off
Find the difference between yours two config her : [url] www.diffchecker.com/mUiHLaxf/ [/url]
This are the right Settings:
SERIAL : "012345680150"
DISK_HOTPLUG : 0x00
LED : 0x03
DISK_IPS_THRES : 0x5
EN_U1U2 : 0x0
FAN : 0x1
DIS_SHOW_EMPTY_DISK : 0x1
UART_DBG_PIN : 0x5
Last edit: 3 years 1 month ago by sdefrwggerg.
  • Wolfspam
  • Wolfspam's Avatar
3 years 1 month ago
Tried the new 1.32.87.082923 and the configuration file would not auto load or manually load for the Orico TCM2-C3-BL-BP Clear blue case, and ORICO-TCM2-C3-RD-BP Red clear case. 1.32.49 worked as expected as it did with all my previous enclosures.
One came originally with 1.24.2 other 1.23.15
3 years 1 month ago
I have the latest firmware on my TUF A1 nickel even the LED works
