3 years 1 month ago
Hi Have you checked the model and revision, otherwise you can revert to the old firmware see the method below
3 years 1 month ago - 3 years 1 month ago
New : Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.32.87
Old
New
Last edit: 3 years 1 month ago by admin.
The following user(s) said Thank You: sdefrwggerg, ole258, shusuke
  • rvail
  • rvail's Avatar
3 years 1 month ago
An Orico branded (RTL9210) NVMe external enclosure purchased from Amazon came from the factory with firmware version 1.24.3. Connected via USB C or USB 3.0 port, the firmware update did not work. Then tried connected to a USB 2.0 port, and the firmware update did actually function. Firmware now on version 1.32.87. Thanks.
The following user(s) said Thank You: admin, viktorhun
  • ole258
  • ole258's Avatar
3 years 1 month ago
I hope, the newer firmware versions include all features from the older ones?
3 years 1 month ago
yes the improvements are made gradually as the versions like a bios fortunately
