- Stasiz
1 year 2 months ago
@Shonk
For collection. SPI dump 1.33.3 from ShuoLe enclosure.
[url]
mega.nz/file/JQhRRLxA#ZE0Qzr15gpMYP8Hv6W...U134Uyr9l408NnG0n4vQ
[/url]
Device : [Port6] : ShuoLe Super SSD #0
PID : 0x0000
MANUFACTURE : "ShuoLe "
PRODUCT : "ShuoLe Super SSD"
SERIAL : "012345678950"
SCSI_PRODUCT : "Super SSD "
SCSI_VENDOR : "ShuoLe "
DISK_HOTPLUG : 0x03
LED : n/a
PINMUX1 : n/a
PINMUX2 : n/a
U2_MAXPWR : n/a
U3_MAXPWR : n/a
ASPMDIS : n/a
DISK_IPS_THRES : n/a
CUSTOMIZED_LED : 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
UART_DBG_PIN : 0x64
UART_BAUD_RATE : 0x0000e100
PERIPH_API : 0x01
FW Ver : 1.33.3
FW Build Date : 2023.09.27
IC Pkg Type : SATA
1 year 2 months ago
thanks
did you remove the chip to dump it and confirm the dump was good with multiple dumps?
I found dumping in situ resulted in random corruption every dump was slightly different
so had to remove the chip
- Stasiz
I did not unsolder the chip. First I made one dump of the box with a color screen with NeoProgrammer, the second dump I made with AsProgrammer. Both dumps were identical. With this dump I successfully flashed the box with a monochrome screen.
NeoProgrammer identifies memory in a case with a color screen as FT25H04, in a case with a monochrome screen as ZB25WD40.
In AsProgrammer I chose N25S40 Nantronics.
Before that I broke the smart information output on the case with a monochrome screen by flashing 1.32.7 firmware.
Apparently this firmware does not support the output of such information. Then I flashed your Cofre Disco Duro 1.33.88 SPI dump. This firmware is newer but does not have PERIPH_API = 0x01 in the configuration responsible for RTL9201R communication with an additional controller for display on the screen.
The original firmware in the case with a monochrome screen was 1.32.62
Device : [Port5] : Realtek RTL9201 #0
PID : 0x9201
PRODUCT : "RTL9201"
SERIAL : "012345678921"
SCSI_PRODUCT : "RTL9201 "
DISK_HOTPLUG : 0x03
LED : n/a
PINMUX1 : n/a
PINMUX2 : n/a
U2_MAXPWR : n/a
U3_MAXPWR : n/a
ASPMDIS : n/a
UART_DBG_PIN : 0x64
PERIPH_API : 0x01
FW Ver : 1.32.62
FW Build Date : 2023.06.05
IC Pkg Type : SATA
Last edit: 1 year 1 month ago by Stasiz.
- m.fessler
1 year 1 month ago
Hello,
I have an Orico 25PW1-C3 that apparently (also) ships with the RTL9201R.
I'm a complete newbie and don't have a programmer.
Is the bridge chip good so far, or does it have serious weaknesses?
UsbTreeView even says it's a 3.2 Gen 2 device (10 Gbps) – is that true, or is this a display error?
I would like to remove the sleep timer and rename "the case".
Is this possible with MPtool_Lite?
Would someone please be so kind as to briefly describe how?
Thank you in advance for any help!
Regards, Martin
Regards, Martin
- hiagoloy
1 year 4 weeks ago - 1 year 4 weeks ago
Recently, I bought an USB-C Enclosure from AliExpress. Brand is Eaget. The issue is that I've noticed that, after a while, maybe a minute or 2, the HDD would kinda 'sleep'. I noticed that on windows, it won't disconnect. But after this time passes, it takes a while to create a new folder or access any file on the HDD. This has been a problem 'cause I'm trying to use the drive and it's really annoying me haha. the chip seems to be RTL9201R. Can you guys help me? I'm a newbie. I've downloaded MPtool_lite and got to this DUMP section which showed me this:
Can I disable this timer the Case seems to have?
PID : 0x9201
PRODUCT : "RTL9201"
SERIAL : "012345678999"
SCSI_PRODUCT : "n/a"
SCSI_VENDOR : "n/a"
DISK_HOTPLUG : 0x03
LED : 0x03
PINMUX1 : n/a
PINMUX2 : n/a
U2_MAXPWR : n/a
U3_MAXPWR : n/a
ASPMDIS : n/a
DISK_IPS_THRES : 0x03
CUSTOMIZED_LED : 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIS_SHOW_EMPTY_DISK : 0x01
UART_DBG_PIN : 0x64
RAID_CFG : n/aBoot Mode : Flash
FW Ver : 1.32.7
FW Build Date : 2022.11.25
IC Pkg Type : SATA
Last edit: 1 year 4 weeks ago by hiagoloy. Reason: Better format of the text
