Hauppauge WinTV Update ( 43251 ) DVB-S2 Drivers ( 08.09.2025 )
- fikotr74
Hauppauge WinTV Update (43251) DVB-S2 Drivers (08.09.2025)
2 years 10 months ago - 11 months 4 weeks agoWinTV v10 Users Manual Download
Please note: due to changes in Microsoft's code signing policy for Windows 7 and 8, new drivers cannot be signed for the 64-bit version of Windows 7 and 8. The WinTV v10 application will work, but the drivers will not install without warning messages. Windows 10 and 11 will install normally.Windows 10 and 11 DriversWindows 10 requires special drivers to avoid errors during the Hauppauge product installation. The latest versions of WinTV v10, WinTV 8.5, WinTV v8 and Hauppauge Capture include these drivers. But if you are looking just for the Windows 10 driver, these are updated drivers which can be used with Windows 10.WinTV and HD PVR DriversEuropean products.
- WinTV-dualHD, WinTV-soloHD
Note: Combo driver for Win10/11 and Win7/8 - WinTV-HVR-935 (Europe DVB, all models)
Note: Combo driver for Win10/11 and Win7/8 - WinTV-NOVA-S2, 461e
Note: Combo driver for Win10/11 and Win7/8 - WinTV-quadHD PCIe model 17xx (new model, after August 2022)
Note: Combo driver for Win10/11 and Win7/8 - WinTV-quadHD PCIe model 16xxxx (old model), WinTV-HVR-1265, WinTV-HVR-1250, WinTV-HVR-1260, ImpactVCBe
Note: Combo driver for Win10/11 and Win7/8 - ImpactVCB-e and WinTV-HVR-1265
Note: Windows 10/11 driver for new models #180100 and 180111 plus the older ImpactVCB-e3 and WinTV-HVR-1265 - Starburst 2, WinTV-HVR-12xx, WinTV-HVR-1700, WinTV-HVR-1500, WinTV-HVR-1400, ImpactVCBe (old model)
WinTV-HVR-55xx, WinTV-HVR-44xx, WinTV-HVR-33xx (150xxx, 121xxx, 53xxx, 69xxx)
Note: Combo driver for Win10/11 and Win7/8 - USB-Live2 (new model 122020)
Note: Combo driver for Win10/11 and Win7/8 - USB-Live2 (old model 122000)
Note: Combo driver for Win10/11 and Win7/8 - WinTV-NOVA-S-USB2, WinTV-NOVA-HD-USB2
- WinTV-Nova-T stick, WinTV-Duet, WinTV-Nova-TD
- WinTV-HVR-900 (65xxx), WinTV-HVR-930 (16xxx)
- WinTV-Ministick, WinTV-Ministick2
- WinTV-HVR-1110
- HD PVR 2 (all models)
- Colossus2
- WinTV-HVR-955Q, WinTV-HVR-950Q, WinTV-HVR-950 and Xbox One TV tuner (ATSC)
Note: Combo driver for Win10/11 and Win7/8 - WinTV-dualHD
Note: Combo driver for Win10/11 and Win7/8 - WinTV-quadHD PCIe model 16xxxx (old model, before August 2022), WinTV-HVR-1265, WinTV-HVR-1250, WinTV-HVR-1260, ImpactVCBe
Note: Combo driver for Win10/11 and Win7/8 - WinTV-HVR-2255, WinTV-HVR-2250, WinTV-HVR-2200
- WinTV-HVR-1975, WinTV-HVR-1955, WinTV-HVR-1950
- WinTV-quadHD USB
Note: Combo driver for Win10/11 and Win7/8 - HD PVR 2 (all models)
- Colossus2
- HD PVR 60
- WinTV-HVR-950 (65xxx), WinTV-HVR-850 (65xxx), WinTV-HVR-850 (111xxx)
- HP Model 133xxx
WinTV v10 & DRiVERS DOWNLOAD Release notes WinTV v10.0.41277
- Matches New WinTVSDK release
- Fixes an issue with blocky TV image on certain satellite DVB-S2 channels.
- Updated hcw85bda driver 1.60.41271 for WinTV-HVR-5525/WinTV-Starburst2 latest revision
Record to network drive (NAS drive). The latest version of WinTV v10 will automatically move your recordings to a network drive after the recordings are complete, freeing up space on your local disk
XMLTV guide data now supported*Please note: due to changes in Microsoft's code signing policy for Windows 7, new drivers cannot be signed for the 64-bit version of Windows 7. The WinTV v10 application will work, but the drivers will not install without warning messages on Windows 7.
Last edit: 11 months 4 weeks ago by fikotr74.
- fikotr74
Re: Hauppauge WinTV TV DVB-S2 Card Drivers 43217 ( 05.08.2025 )
1 year 1 month ago - 1 year 1 month ago- updated WinTV Recorder, to fix issues starting multiple recordings at the same time which could cause recording failures
- optimised WinTV Recorder mutex changes, to avoid waiting a further 2 seconds to release the mutex compared with 43216
Last edit: 1 year 1 month ago by fikotr74.
- fikotr74
Re: Hauppauge WinTV Update ( 43251 ) DVB-S2 Drivers ( 08.09.2025 )
11 months 4 weeks ago - 11 months 4 weeks ago
WinTV v10.0.43251 (BETA)
DOWNLOAD
(08.09.2025)
- Bug fix for video format setting (NTSC,PAL) when using the ImpactVCB-e and USB-Live2. The video format was not correctly set, causing video format issues
- Updated Satellites.xml frequency list for 160.0E and renamed from OPTUS D1 to MEASAT 3A / KOREASAT 6. Also updated satellite channel list for New Zealand.
- Fixed an issue where the padding time could be set to a negative value, causing a recording to fail.
- Added more logging to WinTV Recorder around padding conflicts.
Time to create page: 0.095 seconds
