SAMSUNG SSD990 Pro & SSD 980 Pro Problem
Re: SAMSUNG SSD990 Pro & SSD 980 Pro Problem
Samsung viens de sortir un nouveau firmware Version 1B2QJXD7 pour le Samsung SSD 990 Pro qui est impacté par le taux d'usure des cellules, est-ce un firmware qui corrige le problème ?
La mise à jour et directement proposé par le célèbre utilitaire Magician de Samsung
Aucune information sur les améliorations apportées
Download Firmware
download.semiconductor.samsung.com/resou...990_PRO_1B2QJXD7.iso
Download Magician
www.station-drivers.com/index.php/en-us/....2.1.980/lang,en-us/
Download Firmware
Download Magician
Last edit: 2 years 1 month ago by admin.
2 years 1 month agoConfiguration
The following user(s) said Thank You: Fernando
- tistou77
2 years 1 month ago
Quelles étaient les performances avant la mise à jour du firmware ?
2 years 1 month ago
Le voici
www.station-drivers.com/index.php/en-us/...res-performances#471
Peut etre que Fernando aura des performances meilleurs
- Fernando
@admin: Thanks for having posted the new Samsung Firmware for the 990 Pro SSD!
By the way - you will get much better CrystalDiskMark numbers while testing an NVMe SSD, if you have hit the "Settings" tab and chosen the "NVMe SSD" option.
a) before the FW update:
b) after the FW update:
Here are the benchmark results I got with my AMD X570 chipset system running Win11 x64 on a 1 TB Samsung 990 Pro SSD (in-use NVMe driver: v3.3.2003 WHQL).
Last edit: 2 years 1 month ago by Fernando.
