ssd Samsung SSD 970Pro , 980Pro, 990Pro Firmwares Performances
2 years 3 months ago
#471
Voici les performances des dernieres firmwares pour:
SDD 970Pro Version 1B2QEXP7
SSD 980Pro  Version 5B2QGXA7
SSD 990Pro  Version 0B2QJXD7
Download Firmwares & Utilities
Samsung Magician & SSD Tools & Software Update | Samsung Semiconductor Global
  • Fernando
  • Fernando's Avatar
Re: Samsung SSD 970Pro , 980Pro, 990Pro Firmwares Performances
#472
Which OS and which NVMe driver did you use?
#473
Hi Fernando Hanny New Year
Windows 11 Pro 64 & Drivers Windows
The following user(s) said Thank You: Fernando
  • Fernando
  • Fernando's Avatar
2 years 2 months ago
#480
@admin
Thanks for the addtional information.
By the way - here are the benchmark results I got with the 1 TB Samsung 990 Pro SSD while running Win11 x64 v22H2 on my AMD X570 chipset system:
#482
the performance on an AMD chipset and faster on a PCI-E X4 in NVMe than on Intel Z690 NVMe PCI-E X4 otherwise is the fact that it is in boot (C:) with disk swap?
