  • Silverian
  • Silverian's Avatar
2 weeks 1 day ago
Hello fiko,
I didn't test that specific version yet, but I have tested one of the HP versions that you shared days ago 6.0.10016.1. Let me give it a try and I will reply back.
  • Silverian
2 weeks 1 day ago - 2 weeks 9 hours ago
fiko ,
I have tested the suggested 6.0.10013.1 ALL OEM  from the Microsoft Windows Catalog and the same BSOD popped out unfortunately  .
This is the WinDbg .dmp log:
[color=#1e1e1e]******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: 0000000000000b50, memory referenced Arg2: 0000000000000002, IRQL Arg3: 0000000000000001, bitfield : bit 0 : value 0 = read operation, 1 = write operation bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: fffff800d5eb3a47, address which referenced memory Debugging Details: ------------------ *** WARNING: Unable to verify timestamp for RTKVHD64.sys KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 2593 Key : Analysis.Elapsed.mSec Value: 2614 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 1078 Key : Analysis.Init.Elapsed.mSec Value: 4164 Key : Analysis.Memory.CommitPeak.Mb Value: 82 Key : Analysis.Version.DbgEng Value: 10.0.29617.1000 Key : Analysis.Version.Description Value: 10.2604.29.1 amd64fre Key : Analysis.Version.Ext Value: 1.2604.29.1 Key : Bugcheck.Code.LegacyAPI Value: 0xa Key : Bugcheck.Code.TargetModel Value: 0xa Key : Dump.Attributes.AsUlong Value: 0x21808 Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0x0 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: AV_RTKVHD64!unknown_function Key : Failure.Exception.IP.Address Value: 0xfffff800d5eb3a47 Key : Failure.Exception.IP.Module Value: nt Key : Failure.Exception.IP.Offset Value: 0x2b3a47 Key : Failure.Hash Value: {8427c922-ba45-a12b-e45a-4e0138637121} Key : Faulting.IP.Type Value: Paged Key : Hypervisor.Enlightenments.ValueHex Value: 0x749fcf96 Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 1 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 0 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 0 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 0 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 0 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 38277359 Key : Hypervisor.Flags.ValueHex Value: 0x24810ef Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015 Key : Hypervisor.RootFlags.ValueHex Value: 0x3f7 Key : WER.System.BIOSRevision Value: 15.55.0.0 BUGCHECK_CODE: a BUGCHECK_P1: b50 BUGCHECK_P2: 2 BUGCHECK_P3: 1 BUGCHECK_P4: fffff800d5eb3a47 FILE_IN_CAB: 083026-15734-01.dmp TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b DUMP_FILE_ATTRIBUTES: 0x21808 Kernel Generated Triage Dump FAULTING_THREAD: [/color][color=#0000ff]ffffd7897df95080 [/color][color=#1e1e1e]WRITE_ADDRESS: fffff800d6bc54d8: Unable to get MiVisibleState 0000000000000b50 BLACKBOXBSD: 1 ([/color][color=#0000ff]!blackboxbsd[/color][color=#1e1e1e]) BLACKBOXNTFS: 1 ([/color][color=#0000ff]!blackboxntfs[/color][color=#1e1e1e]) BLACKBOXPNP: 1 ([/color][color=#0000ff]!blackboxpnp[/color][color=#1e1e1e]) BLACKBOXWINLOGON: 1 ([/color][color=#0000ff]!blackboxwinlogon[/color][color=#1e1e1e]) ([/color][color=#0000ff]!blackboxwinlogonnotify[/color][color=#1e1e1e]) CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System IP_IN_PAGED_CODE: nt!KeCancelTimer+67 fffff800`d5eb3a47 f00fba2f07 lock bts dword ptr [rdi],7 STACK_TEXT: ffff8080`8360d128 fffff800`d62c04e9 : 00000000`0000000a 00000000`00000b50 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx ffff8080`8360d130 fffff800`d62bb7a8 : 00000000`00000000 00000000`00000000 00000000`00000b50 00000000`00000000 : nt!KiBugCheckDispatch+0x69 ffff8080`8360d270 fffff800`d5eb3a47 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff800`d5ed447b : nt!KiPageFault+0x468 ffff8080`8360d400 fffff804`d65303d2 : 00000000`00000000 fffff804`d66f00d0 00000000`00000000 ffffd789`7e736bf0 : nt!KeCancelTimer+0x67 ffff8080`8360d4a0 00000000`00000000 : fffff804`d66f00d0 00000000`00000000 ffffd789`7e736bf0 ffffd789`7dce0bc0 : RTKVHD64+0x403d2 SYMBOL_NAME: RTKVHD64+403d2 MODULE_NAME: [/color][color=#0000ff]RTKVHD64 [/color][color=#1e1e1e]IMAGE_NAME: RTKVHD64.sys STACK_COMMAND: [/color][color=#0000ff].process /r /p 0xffffd789794aa040; .thread /r /p 0xffffd7897df95080 ; kb [/color][color=#1e1e1e]BUCKET_ID_FUNC_OFFSET: 403d2 FAILURE_BUCKET_ID: AV_RTKVHD64!unknown_function OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {8427c922-ba45-a12b-e45a-4e0138637121} Followup: MachineOwner ---------[/color]
And...
Please allow me to clarify this is the first time I used Driver Fusion, I have been using Iobit Driver Booster for about 5 years. What would you suggest at this point?
Last edit: 2 weeks 9 hours ago by Silverian. Reason: Added WinDbg .tmp code
  • fikotr74
  • fikotr74's Avatar
2 weeks 21 hours ago - 2 weeks 21 hours ago
fiko ,
And...
Is your system installed as an old MBR or UEFI? Because many current drivers now only support UEFI. If it's MBR, I think you can only use MBR-supported drivers.
I'm experiencing the same problem on a PC that doesn't support UEFI. That's the last thing that came to my mind.
I use "Driver Genius" and "Driver Booster".
Last edit: 2 weeks 21 hours ago by fikotr74.
  • josefrancklin
  • josefrancklin's Avatar
2 weeks 15 hours ago - 2 weeks 15 hours ago
  • I am not not sure why, but even if hardware ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0295&SUBSYS_103C8615 is present inside every HDXHAPHPNB.inf driver I have tested (supposed to be compatible), I am still getting the BSOD.
Hi Silverian,
Last edit: 2 weeks 15 hours ago by josefrancklin. Reason: Add information
  • Silverian
2 weeks 9 hours ago
fiko ,
And...
My Windows 11 NVME is formated with GPT partition using entirely UEFI, CSM is disabled and Secure Boot is enabled on my BIOS.
