Intel Management Engine (ME) Firmware 16.1.42.2872 Consumer LP 1.5Mb
- Castillot
1 week 6 days ago - 1 week 6 days ago
Hi!
Is there another Intel Management Engine (ME) Firmware 16.1.42.2872 Consumer LP 1.5Mb Production. I downloaded the available version from station-drivers but got this error: 'Error 366: Failed to verify signature of OEM or RoT key manifests. For example: Error on update from Production to Pre-Production.'
Here is the ME info from my Lenovo Neo 50a 24 Gen 5 Desktop (ThinkCentre) - Type 12SC:
Platform Type Mobile
FW Image Type Production
Last ME Reset Reason Other
BIOS Boot State (EOP) Post Boot
BIOS Boot State (CBD) Post Boot
Boot Critical Code Redundancy Disabled
Current Boot Partition 1
OEM Chipset Init Available
OEM Chipset Init Version 12.0.5121.65535
Factory Defaults Restoration Status Disabled
CPUID 0xB06A2
Factory Defaults Recovery Status Enabled
Firmware Update OEM ID 4C656E6F-766F-0000-0000-000000000000
Intel(R) ICPS SW SKUing Eligible Disabled
Camera privacy feature control disabled True
Crypto HW Support Enabled
Intel(R) ISH Power State Disabled
OEM Tag 0x00
FW Update State Enabled
TLS State Enabled
CSME Measured Boot to TPM Disabled
BIOS Recovery State Enabled
Intel(R) ME Code Versions
BIOS Version O6AKT28A
MEI Driver Version 2603.9.4.0
FW Version 16.1.40.2765 LP Consumer
Extended Platform Services
License Installed False
License Period 0 Periods
IUPs Information
PMC FW Version 160.1.0.1031
OEM FW Version 0.0.0.0000
IOM FW Version 36.7.0.0000
NPHY FW Version 14.531.509.8259
TBT FW Version 16.1.35.2303
PCHC FW Version 16.1.0.
PCH Information
PCH Name ADL
PCH Device ID 519D
PCH Revision ID A1
PCH SKU Type Production PRQ Revenue
PCH Replacement State Disabled
PCH Replaceable Counter 0
PCH Unlocked State Disabled
Transactional FW Information
Original image type Consumer
Current sku type Consumer
Flash Information
Storage Device Type SPI
SPI Flash ID 1 EF4017
SPI Flash ID 2 207018
RPMC Supported
RPMC Bind Counter 1
RPMC Bind Status Post-bind
RPMC Rebind Supported
RPMC Replay Protection Max Rebind 15
BIOS Read Access 0x000F
BIOS Write Access 0x000A
GBE Read Access 0x0009
GBE Write Access 0x0008
ME Read Access 0x000D
ME Write Access 0x0004
EC Read Access 0x0101
EC Write Access 0x0100
FW Capabilities 0x31309200
Intel(R) Protected Audio Video Path Present/Enabled
Intel(R) Dynamic Application Loader Present/Enabled
Intel(R) Platform Trust Technology Present/Enabled
Persistent RTC and Memory Present/Enabled
End Of Manufacturing
NVAR Configuration State Locked
EOM Settings Lock(Flash,Config)
EOM Flow Full
HW Binding State Enabled
Flash Protection Mode Protected
FPF Committed Yes
PAVP State Yes
Security Version Numbers
Trusted Computing Base SVN 1
Firmware Version Control SVNs
PMC 0 [minimum allowed: 0]
CSE 6 [minimum allowed: 0]
ROT KM 0 [minimum allowed: 0]
IDLM 0 [minimum allowed: 0]
CSME bootstrap 0 [minimum allowed: 0]
SECURE BOOT BSMM 1 [minimum allowed: 0]
OEM KM 0 [minimum allowed: 0]
SECURE BOOT KM 1 [minimum allowed: 0]
UCODE 1 [minimum allowed: 0]
SECURE BOOT ACM 2 [minimum allowed: 0]
HW Glitch Detection 0x18C9
TRC Polarity Rising Trans
TRC Mode Full-cycle polarity trans
TRC State Enabled
Intel(R) PTT initial power-up state Enabled
Intel(R) PTT State Enabled
SMx State Enabled
RSA1K Support Disabled
Debug Information
Token Present No
Token Handling Status Not Available
Invalid Knob Detected Not Available
Consent No
DFx Policy Unprivileged Public Debug Enabled
FW Supported FPFs FPF UEP
*In Use
1st OEM Key Hash Revoked Disabled Disabled
1st OEM Key Hash size Enabled Enabled
1st OEM RSA Key size Enabled Enabled
2nd OEM Key Hash Revoked Disabled Disabled
2nd OEM Key Hash size Enabled Enabled
2nd OEM RSA Key size Enabled Enabled
BSMM Firmware Version Control Enabled Enabled
CSE FW Firmware Version Control Enabled Enabled
CSME Bootstrap Firmware Version Control Enabled Enabled
DNX Firmware Version Control Enabled Enabled
Error Enforcement Policy 0 Enabled Enabled
Error Enforcement Policy 1 Enabled Enabled
Flash Descriptor Verification Disabled Disabled
Glitch Detection Disabled Enabled Enabled
IDLM Firmware Version Control Enabled Enabled
Intel PTT Encryption Key Not Revoked Not Revoked
Intel(R) Manageability HW Fuse Status Enabled Enabled
Intel(R) PTT Enabled Enabled
OEM ID 0x00 0x00
OEM KM Firmware Version Control Enabled Enabled
OEM Key Manifest Enabled Enabled
OEM Key Revocation State Disabled Disabled
OEM Platform ID 0x00 0x00
OEM Secure Boot Policy 0x6F 0x6F
CPU Debugging Disabled Disabled
BSP Initialization Disabled Disabled
Protect BIOS Environment Enabled Enabled
Measured Boot Disabled Disabled
Verified Boot Enabled Enabled
Key Manifest ID 0x01 0x01
Force Boot Guard ACM Enabled Enabled
OEM key Hash RSA key size Enabled Enabled
PID Refurbish Counter 0x00 0x00
PMC Firmware Version Control Enabled Enabled
PTT Lockout Override Counter 0x00 0x00
Persistent PRTC Backup Power Enabled Enabled
ROT Firmware Version Control Enabled Enabled
RPMB Monotonic Counters 0x00 0x00
RPMC Over EC Disabled Disabled
RPMC Rebinding Enabled Enabled
RPMC Support Enabled Enabled
SOC Config Lock State Enabled Disabled
SPI Boot Source Enabled Enabled
SPIRAL CPU Enabled Enabled
Secure boot KM Firmware Version Control Enabled Enabled
TXT Supported Disabled Disabled
UFS Boot Source Disabled Disabled
uCode Firmware Version Control Enabled Enabled
DNX SVN 0x00 0x00
IDLM SVN 0x00 0x00
OEM KM SVN 0x00 0x00
PMC SVN 0x00 0x00
ROT KM SVN 0x00 0x00
Secure boot ACM SVN 0x00 0x00
Secure boot BSMM SVN 0x00 0x00
Secure boot KM SVN 0x00 0x00
Ucode SVN 0x00 0x00
Intel (R) FW Update Version: 16.1.38.2681
Copyright (C) 2005 - 2025, Intel Corporation. All rights reserved.
Checking firmware parameters...
Warning: Do not exit the process or power off the machine before the firmware update process ends.
Sending the update image to FW for verification: [ COMPLETE ]
Do not Interrupt
Error 369: Failed to verify signature of OEM or RoT key manifests. For example: Error on update from Production to Pre-Production.
CPUID 0xB06A2
OEM Tag 0x00
TLS State Enabled
IUPs Information
PCH Information
PCH Name ADL
PCH Device ID 519D
PCH Revision ID A1
Flash Information
RPMC Supported
RPMC Bind Counter 1
EOM Flow Full
FPF Committed Yes
PAVP State Yes
TRC State Enabled
SMx State Enabled
Debug Information
Token Present No
Consent No
*In Use
OEM ID 0x00 0x00
DNX SVN 0x00 0x00
IDLM SVN 0x00 0x00
PMC SVN 0x00 0x00
Ucode SVN 0x00 0x00
Do not Interrupt
Last edit: 1 week 6 days ago by Castillot.
