Marvell/Aquantia AQC113, AQC113C, AQC113CS (10Gbps) Firmware Version 1.5.48
- BrN
Re: Marvell/Aquantia AQC113, AQC113C, AQC113CS (10Gbps) Firmware Version 1.5.48
2 months 3 weeks ago
Ne fonctionne pas chez moi. J'ai bien saisie les Ids de mon périphérique, mais j'ai un message d'erreur que je ne comprends pas.
- misal1337
- Poster
2 months 3 weeks ago - 2 months 3 weeks agoExtract FirmwareUpdate_v1.5.48.exe into a folder using NanaZip or any extractor and browse to it in elevated cmd.
Syntax once you are in the firmware directory in Windows with latest driver 3.1.11.0 ->
flashUpdate2.exe --update ATL2-8.0.1_agent_SIGN.clx AQC113-Lenovo-Vulcan-1.5.48_aqsign.clx
I have updated 4 cards so far and all have succeeded. TP-Link, Asus XG-C100C, Asus X870E ProArt and IOCrest 10G Thunderbolt USB-C enclosure.
I am just unable to revive my QNAP QXT-10G-2T. It got borked with previous firmware. Looks like it's gone for good.
Last edit: 2 months 3 weeks ago by misal1337.
The following user(s) said Thank You: BrN
- BrN
Thanks for your answer. With your command, i've flashed successfully my IOCrest 10G Thunderbolt USB-C enclosure.
Thanks a lot !
Thanks a lot !
Thanks
d5aqoep
- jmsth
2 months 2 weeks ago
Hello
I noticed you also had an "Asus Z890 ProArt" - I have that board as well. Did you apply this updated firmware to the AQC113C on it? I'm always a bit hesitant touch a board's integrated devices. Was it successful and, if so, does it provide the ASPM L1 fixes (similar to DirtyWake/Arie)?
Thank you!
Thank you!
