Intel I226–V Lan Controllers Firmware NVM Version 2.29/2.32
5 months 2 days ago - 5 months 2 days ago
My chipset
NVMUpdate version 1.42.8.0
Copyright(C) 2013 - 2024 Intel Corporation.
nvmupdatew64e.exe -i -l inventory.txt
Config file will not be read.
Inventory
[00:133:00:00]: Intel(R) Ethernet Controller I226-V
    Flash inventory started.
    Shadow RAM inventory started.
    Flash inventory finished.
    Vendor                 : 8086
    Device                 : 125C
    Subvendor              : 1043
    Subdevice              : 8867
    Revision               : 6
    LAN MAC                : xxxxxxxxxxx
    Alt MAC                : 000000000000
    SAN MAC                : 000000000000
    ETrackId               : 8000039D
    SerialNumber           : A0AD9FFFFFA10858
    NVM Version
 : 2.35(2.23)
    PBA                    : G23456-000
    VPD status             : Not set
    VPD size               : 0
    NVM update             : No config file entry
      checksum             : Valid
My NVM firmware cannot be updated, probably due to my newer version.
For those interested, you just need to modify the "config_i226.txt" file with your chipset ID codes and then run the command "nvmupdatew64e.exe -u -l -c config_i226.txt" in CMD.
Release note:
Fixes an issue in MDI lane swap handling that caused the P (positive) and N (negative) signal polarities to be swapped incorrectly.
Please note that the update has risks that it may fail, Station-Drivers and Fdrsoft cannot be held responsible in the event of a crash. !
Firmware 2.32 is included in the package, which you can download here Version 1Mo & 2Mo.
Intel-I226-V-NVM-Firmware/I226-V at main · BillyCurtis/Intel-I226-V-NVM-Firmware · GitHub
www.station-drivers.com/index.php/en/com....29-2.32/lang,en-gb/
Last edit: 5 months 2 days ago by admin.
The following user(s) said Thank You: geneticsystem2013
