lan Firmware 1.94 (i225-V)
  • ppanthagod
  • ppanthagod's Avatar
Re: Firmware 1.94 (i225-V)
7 months 2 days ago
#3431
Guys i think i bricked my NIC. Flashed it with FW from this topic. Tried to downgrade and now i have NIC Start Failure. Has someone original DUMP from I225-V REV03 from an Z690 ASUS Board?
I tried all FWs and i dont know how to use -f command. Thx
7 months 2 days ago
#3432
try reflashing the bios hoping it will put back the old firmware, is it still recognized?
Before updating, check carefully that the firmware concerns Rev 1.x, rev 2.x or 3.x.
  • ppanthagod
7 months 2 days ago
#3434
Ok ill try to reflash Bios later. Ya it is in Device Manager but with the error that it cant be started.
  • oemuser
  • oemuser's Avatar
  • Poster
  • Poster
7 months 2 days ago - 7 months 2 days ago
#3435
What NVM version were you in?
What Asus Z690 model?
Did you made backups...no, irresponsible stupid action then...
If its in the device manager, its a good sign...
Basic cmds here
EEUPDATEW64e.exe /nic=1 /eepromver (optional output to file: nic.log/txt)
nvmupdatew64e.exe -i -l (optional output to file: nic.log/txt)
Read the other thread about the 1.89 FW , similar issues from users and how were recovered may help.
The reflash BIOS option will probably not going to work...
Last edit: 7 months 2 days ago by oemuser.
  • ppanthagod
#3437
Basic cmds here
It was 1.89 before 1.94 update
ROG STRIX Z690-A GAMING WIFI D4 so REV03
i have a Realtek PCI Card what i am using most of the time, just tried to fix the connection losses before i sell the board. I can start the flash process but it says RAM is unassigned or something, i cant force the update -f, it says wrong or bad parameter.
Last edit: 7 months 2 days ago by ppanthagod.
