cpu Intel Management Engine Interface (MEI/AMT) Version 2240.3.4.0 WHQL
  • SM-003
  • SM-003's Avatar
  • Moderator Global
  • Moderator Global
Re: Intel Management Engine Interface (MEI/AMT) Version 2240.3.4.0 WHQL
#1581
The latest post for v 2331.5.20.0 WHQL  isn't working.
500 Internal Server Error
System H/W Specifications
Last edit: 1 year 7 months ago by SM-003.
1 year 7 months ago
#1583
Fixed link sorry
  • fylgja
  • fylgja's Avatar
Re: Intel Management Engine Interface (MEI/AMT) Version 2328.5.16.0
1 year 6 months ago
#1675
2328.5.16.0 (11/07/23) is not support Win7.
require Win8 or highter.
  • Tom's Avatar
1 year 6 months ago
#1677
What makes you think like that?
Because you only see the folder Win8?
The inf-file specifies [Intel.ntamd64.6.2] which refers to Windows 7 and up, the WHQL certificate lists also OSAttrib 2:6.2, 2:6.3,2:10.0 for Windows 7 and up.
6.3 is Windows 8.1 and 10.0 refers to Windows 10 and up.
  • fylgja
  • fylgja's Avatar
1 year 6 months ago
#1678
reason 1
NT6.0 : Windows Vista
NT6.1 : Windows 7
NT6.2 : Windows 8
NT6.3 : Windows 8.1
reason 2
Windows 7 : TEEDriver.sys / TEEDriverx64.sys
Windows 8.x : TEEDriverW8.sys / TEEDriverW8x64.sys
