cpu Intel Management Engine Interface (MEI/AMT) Version 2435.6.35.0
#3575
www.station-drivers.com/index.php/en/com...5.6.35.0/lang,en-gb/
Last edit: 6 months 2 weeks ago by admin.
The following user(s) said Thank You: grimson, duttyend, fikotr74
  • DRMiner
  • DRMiner's Avatar
Re: Intel Management Engine Interface (MEI/AMT) Version 2435.6.35.0
#3580
SetupME.exe will not launch in Windows 11. Error Message: "This platform is not supported."
#3581
Yes because only for platforms with firmware 10.xx/11.xx/12.xx
  • Almighty1
  • Almighty1's Avatar
#3586
Did you post the correct version # as the screenshot says 2433.6.3.0
#3587
The pack often does not have the same version as the HECI driver
