cpu Intel Management Engine Interface (MEI/AMT) Version 2238.3.31.0 WHQL
2 years 5 months ago
#163
Firmware ME: 1.5MB & 5Mo
  • Serie: 10.x/11.x/12.x/13.X/14.x/15.x/16.x/18.x/19.x/20.x
  • Pack Version: 2238.3.31.0 (15/09/22)
  • Firmware Version: 16.1.25.1932
  • Date & Version du drivers:
  • MEI : 07/14/2022,2229.3.2.0
  • MEI Ext: 07/14/2022,2229.3.2.0
  • SOL : 05/02/2022,2219.3.0.0
  • SOL Ext: 07/04/2022,2131.1.73.1 New
  • WIMAN: 09/13/2022,2238.71.65.0 New
  • WIMAN Ext: 09/13/2022,2238.71.65.0 New
  • WHQL: oui
  • Officiel: non
  • Release note:
  • Version 2238.3.31. Fixed release for MESW IPU2022.3 Intel-TA-00610.
Download:
www.station-drivers.com/index.php/en-us/...on-2238.3.31.0-WHQL/
  • tistou77
  • tistou77's Avatar
Re: Intel Management Engine Interface (MEI/AMT) Version 2238.3.31.0 WHQL
#167
HECI driver is for Windows 7 and 8 only
  • Tom's Avatar
#169
Nope, the WHQL signature lists also Windows 10 in the Win8 folder.
Edit: it's the same driver like package v2233.3.26.0, only Windows 8 is now also additional certified.
Last edit: 2 years 5 months ago by Tom.
  • tistou77
  • tistou77's Avatar
#170
Yes MS certified them for W10/11 but they are not "optimized" for them
The sys file is TEEDriverW8x64.sys, for Windows 10/11 it is TEEDriverW10x64.sys
But it works, just that it's better to use those provided for the OS
I had discussed it on the Intel forum for Windows 10
  • Tom's Avatar
#171
As I said, the HECI driver carries the same version number as in the previous package, I cannot judge whether it is optimized for Windows 10/11 or not.
For me it looks more like a bugfix release, considering that there are several drivers missing compared to the previous version and the HECI driver adds the Windows 7/8 support.
The Teedriver binary carries also the same version number, however the Windows 10 binary is slightly bigger size.
Anyway, a Windows 10/11 user won't "update" the driver if he had already the previous package installed.
