Intel Management Engine Interface (MEI/AMT) Version 2238.3.31.0 WHQL
2 years 5 months ago
Firmware ME: 1.5MB & 5Mo
Download:
www.station-drivers.com/index.php/en-us/...on-2238.3.31.0-WHQL/
- Serie: 10.x/11.x/12.x/13.X/14.x/15.x/16.x/18.x/19.x/20.x
- Pack Version: 2238.3.31.0 (15/09/22)
- Firmware Version: 16.1.25.1932
- Date & Version du drivers:
- MEI : 07/14/2022,2229.3.2.0
- MEI Ext: 07/14/2022,2229.3.2.0
- SOL : 05/02/2022,2219.3.0.0
- SOL Ext: 07/04/2022,2131.1.73.1 New
- WIMAN: 09/13/2022,2238.71.65.0 New
- WIMAN Ext: 09/13/2022,2238.71.65.0 New
- WHQL: oui
- Officiel: non
- Release note:
- Version 2238.3.31. Fixed release for MESW IPU2022.3 Intel-TA-00610.
Download:
- tistou77
Re: Intel Management Engine Interface (MEI/AMT) Version 2238.3.31.0 WHQL
2 years 5 months agoLL A77F - Rampage VI Extreme Encore - 10980XE @4.7ghz - G.Skill Trident-Z RGB Royal 4x8Go @4000 C16 - EVGA RTX 2080ti XC Ultra - Seasonic Prime Ultra Titanium 1000W - Intel Optane 905P et Samsung 990 Pro - Asus Xonar Phoebus
Nope, the WHQL signature lists also Windows 10 in the Win8 folder.
Edit: it's the same driver like package v2233.3.26.0, only Windows 8 is now also additional certified.
Last edit: 2 years 5 months ago by Tom.
- tistou77
Yes MS certified them for W10/11 but they are not "optimized" for them
The sys file is TEEDriverW8x64.sys, for Windows 10/11 it is TEEDriverW10x64.sys
But it works, just that it's better to use those provided for the OS
I had discussed it on the Intel forum for Windows 10
As I said, the HECI driver carries the same version number as in the previous package, I cannot judge whether it is optimized for Windows 10/11 or not.
For me it looks more like a bugfix release, considering that there are several drivers missing compared to the previous version and the HECI driver adds the Windows 7/8 support.
The Teedriver binary carries also the same version number, however the Windows 10 binary is slightly bigger size.
Anyway, a Windows 10/11 user won't "update" the driver if he had already the previous package installed.
